Question about Motorola Mobility RAZR V3
Phone shuts off during operation.
My RAZR keeps shutting down when I'm talking to someone or when I'm dailing.  Battery is fully charged.
  • Dakis Oct 18, 2007
    Swapped it out with another battery and it seems to be working OK.  So I'm hoping that was it. Thanks for all the help.
  • 425 Answers
Hi
im sure you have a batt prob...
have your batt replaced and im sure your prob is solved...
Posted on Oct 16, 2007
SOURCE:
Phone shut off during use and will not turn back on with full charge.
did you try getting a replacement battery or sending the phone in to be fixed
Aug 30, 2012 | Motorola Mobility XT912 Droid Razr Verizon...
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Battery is fully charged. phone power randomly shuts off.
Hi, When a cell phone is fully charged and the cell phone randomly shuts off,IT means that the battery of the cell phone is ok ,but the cell phone memory is faulty and it need to be checked out.
I this kind of case, i would advice you take it to an expert on phone repairs tohelp you look into it. That will do..
Hope it helped /..
Thanks for using fixya,
Feb 03, 2011 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr V3 shuts down during Hello Moto screen. We can't get to any menus.
Does it do this when it's connected to a charger?
Is the battery fully charged up?
Try starting it up with no SIM card. It should boot to "emergency use" screen. If so, then your SIM is bad and you need a new one from your carrier
Jan 19, 2010 | Motorola Mobility RAZR V3
Cell phone shuts of continuously
check the battery. and charge it fully.
Jun 26, 2009 | Motorola Mobility RAZR V3
Motorola Cherry Blossom Razr keeps freezing...
it is best to take the phone back n have it replaced......the phone needs the firmware flash to correct this issue....
Dec 27, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Phone goes off while talking
the solution to these change the battery
Nov 20, 2008 | Motorola Mobility RAZR V3
Motorola V3 keep shutting down
Try a new battery if that does not work then you should take the phone and have the firmware flash to correct this error.....take the phone to a mobile service center to have this done.
Oct 25, 2008 | Motorola Mobility RAZR V3
Phone shuts down during a charge
change the battery and if that does not work take the phone and have the service center reflash the firmware on the phone this method should correct it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
126 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
