Question about Jabra BT350 Bluetooth Headset Headset
Passkey of 4 zeroes does not work
I am trying to pair the Jabra BT350 to my new Motorola MOTOSLVR L7C.  I tried 0000 when prompted for the passkey.  It comes back and tells me this passkey is incorrect and does not pair successfully.
  • Anonymous Apr 26, 2008
    Same as above
I have the exact problem.. but you try to turn off and on your phone once again.. and then do the pairing instruction.... using the passkey 0000.. then... it works for me again...
Posted on Jul 21, 2008
Try either 1234 or the last 4 digits to your actual cell phone number. Those might work.
Posted on Nov 20, 2007
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
Trying to pair my Jabra VBT2050 to my motorola. The passkey 00000 isn't working
you can only use one digit number not four digit..to detect the bluetoot headset
Sep 30, 2010 | Jabra BT350 Bluetooth Headset Headset
Hello, I am trying to pair my Jabra BT350 to my Blackberry Curve. My Blackberry is requesting a numeric passkey. Do you know the numeric passkey? Thank you
The numeric passkey is 0000 (4 zeros).
For more details, download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Aug 17, 2010 | Jabra BT350 Wireless Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Mar 10, 2008 | Jabra BT350 Bluetooth Headset Headset
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
710 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
