Question about Logitech MX700 CORDLESS OPTICAL MOUSE W/RAPID CHARGE BASE STATION (LOGMX700)
Mouse not functioning
I have installed the software provided with the mouse, do I have to activate anything on the computer or should there be a dongle or bluetooth adaptor. Hoping someone can assist woith this problem, thanking you in anticipation. Frank Roberts.
  • Frank Roberts Oct 12, 2007
    Thankyou for your quick and successful response. Quarterbat
  • 78 Answers
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Posted on Oct 12, 2007
  • Paul
    Paul Oct 12, 2007
    almost there? can you advise where you are on this. does it have a USB connection? did the computer detect it? if this is yes my next step would be to remove the batteries from the mouse and reinstall then resync it. If not could you give more information.
SOURCE:
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
LLogitech wireless mouse LX5
ok.. got your email.. kindly wait and i send it right there..
thanks
Apr 16, 2008 | Logitech LX5 Cordless Optical Mouse
Install to new computer but do not have installation cd
Go to the manufacturer's website and look for drivers or software for your particular mouse. Most allow you to download the installation software for free...
Mar 19, 2014 | Compucessory Corded Mice 40912 Laser...
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
How do yoou connect a wireless mouse to your computer
Buy a wireless adapter that works with your mouse. If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Power on the mouse and let the computer recognize the new hardware. If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
Hope this helps
Nov 04, 2012 | Computers & Internet
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
May 09, 2011 | Computers & Internet
I am not able to use my mouse on my laptop. The arrow on the screen does not move. I have followed all the instuctions.
prior mouses were cable connection required to acheive functionalities. For example, the mouse had to be connedted to the computer by the cable connection, and a software prorgam installed to attain functions. Recent computer mouses are wireless operate. For example, the mouse only requires batteries in to device, and a separate device connected to the computer called a wireless mouse adapter. Usually the wireless mouse should capture the network devices signals least requiring a program installed. Observe the mouse to ascertain that is cabled or wireless networked.
Feb 09, 2011 | Kensington Computers & Internet
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
Jumpy mouse
Buy A Mouse Trap if the darn mouse is jumping everywhere
LOL
Did you just install and did come with any software
have you checked in control under pointing devices or mouse and see you have a setting in there
Jan 17, 2009 | Logitech 9311570403 Mouse
I am trying to install a logitech nano cordless laser for but it does not seem to be functioning. I've installed all the software and restarted the computer numerous times and still no mouse activity. My...
I contacted Logitech and registered a problem with them and they are working on it now. I did not realize that your site required a fee for advice and I'm sorry for bothering you. Thanks anyway.
Paul Geise
Jul 21, 2008 | Computers & Internet
Logitech MX700 CORDLESS OPTICAL MOUSE W/RAPID CHARGE BASE STATION (LOGMX700) Logo
327 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
