Question about Boating
350 chevy marine engine has a noise when going above 2500rpm, no noise at idle or running 10knots or less, when not neutral I ran throttle up to 5000rpm no noise over 6000rpm slight noise but nothing like when in gear Thanks in advance for any help, Jim
  • millrun07 May 11, 2009
    thanks I will check this weekend and let you know
  • 5,677 Answers
Sounds like its a drivetrain problem. Just for fun check your prop hub, it could be slipping under heavy load. If you have u-joints they could be going bad. Sometimes if the outdrive is pitched up too far on I/O units it is an uncomfortable bend for the U-Joints. There are limit adjustments for the I/O to prevent that from happening in gear.
Posted on May 11, 2009
How can I lower my IDLE?
I have heard that air in the coolant will affect the idle speed, also a vacuum leak.
Your English seems perfect to me.
Apr 16, 2015 | 2003 Honda Accord
Fuel delivery on carb 350 chevy marine engine
Hi!
It seems your fuel pump fails at idle speed. I would first ensure that fuel pump is well fitted, no leaks, and good diaphragm condition.
Jun 01, 2008 | 1983 Chevrolet Malibu
1995 chevy 350 egr valve problem, i just replaced the new egr valve and it has less proplems now. when the engine is warm after 10 mins of riding, it still has a proplem when slowing down, engine stops....
SOUND LIKE FAULTY IDLE AIR CONTROL MOTOR.TAKE VECHICLE TO GARAGE LET THEM SCAN VECHICLE.IF IDLE SPEED CONTROL FAULTY.IT HAS TO BE REPLACED AND REPROGRAMMED.
Oct 07, 2010 | Cars & Trucks
I have a 1992 Chevy pick up 1500 series. 350 engine. The idle is running low on it, were and how can I adjust it?
If the vehicle has a automatic transmission, check the Neutral Safety Switch. If defective from wear it could be sending incorrect signals to the Electronic Control Module which in turn sends signals to the Idle Air Control. It will make the computer think the transmission is in gear and lower the RPMs and then when the transmission is actually in gear the physical load will lower the RPMs even more. To check, set the parking brake and move the gear selector to Neutral and check the RPMs to see if the engine maintains a constant 650 +/-. Next, shift to Drive and check if RPMs drop to and maintain 500 +/-. If it does then you have diagnosed the problem. The original equipment Idle Air Control motors rarely wear out.
Aug 05, 2010 | 1992 Chevrolet K1500
What is the difference between a marine chevy 350
The engines are the same. The exhaust manifolds and the cooling system are the only differences.
Oct 31, 2017 | Boating
2006 chevy silveado 2500hd 6.ol 92,000 miles no oil pressure!
Oil pressure is created by the oil pump, the main bearings and cam bearings. If these bearing are worn, excessive clearance, you will lose oil pressure. The rattling could be a rod bearing or wrist pin. You could try installing a "wet gauge" and check the oil pressure against the OEM specs, at different RPMS.
Mar 08, 2010 | Chevrolet 2500 Cars & Trucks
Chevy 350 express van 2000 runs great idles rough
If it does not do it in park or neutral, it could be a number of things. One being a sticking Torque Converter Clutch solenoid (TCC). It could be that it needs a simple tune-up. How often does this problem happen?
Jun 29, 2009 | 1996 Chevrolet Suburban
High idle CHevy 350 TBI
check if went from a V6 TO V8 need power two more cylinders
Jun 20, 2009 | 1992 Chevrolet K1500
1990 chevy camaro with a rebuilt 350 Tbi
fuel pressure isnt right.. need to get a fuel pressure regulator so you can regulate the gas flow..
Apr 21, 2009 | 1990 Chevrolet Camaro
High CO emissions
run the fault codes and look for problem heated oxygen sensor ( HO2S) in the exhaust manifold , or problem oxygen sensor (O2S) after the cat converter, problem EGR system or problem cat converter
Apr 05, 2017 | 1995-1997 Chevy Suburban Ignition Starter...
Boating Logo
132 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
