Question about Dryers
Electric kenmore 90 series working but no heat?
My kenmore 90 series electric dryer works but no heat?
  • drummer1908 May 13, 2009
    replaced thermal fuse still not heating, any other ideas? thanks.
  • Dryers Master
  • 8,220 Answers
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
Posted on May 10, 2009
  • Dan Webster
    Dan Webster May 13, 2009
    check each little gizmo on the dryer that the wires attach to. All the
    little black thingies attached to the side of the heat element, the
    door switch (when door is closed) etc.should have continuity (closed
    circuit) If you come
    across any little thingie near the blower housing with 2 wires attached
    to it, well that a sensor, a safety (Now so as not to get a false
    circuit you need to remove one of the wires to each thingie you check) These
    things blow because of lint and too many clothes or blocked vent going
    out the house or all of the above. You element could be broken. If all of that is dood and you know you have 240 coming in, then replace the timer. OR repair the timer. Open it up and file down the burnt points. The leg from heating element to timer marked RH typically burns or gets a burr on the points up inside the timer. A file and some effort will make it right.
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
KENMORE 90 SERIES GAS DRYER NO HEAT IS THERE A PILOT
heatman101
Jun 27, 2011 | Kenmore Dryers
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
432 people viewed this question
Top Dryers Experts
