Question about Husqvarna Viking 1
MegaQuilter Tension My MegaQuilter is driving me nuts! Someone please help! If I adjust top tension (to stop thread bunching on the bottom side of the quilt), then my thread shears off and breaks at the needle point. If I back off of the tension - even just a little bit - then the thread doesn't break anymore, but the backside of the quilt looks horrible again. What am I doing wrong?!? I've threaded and re-threaded and reseated the bobbin as well, but neither seems to work.
  • littlemkl May 12, 2009
    Thanks! I did try a new needle, and Inspira 90 Topstitch, that was reccommended by my dealer. It works perfectly now......I've been flying through quilts all morning! Thanks for the tip!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Try at least 2 new needles first (HLX5, preferably Schmetz). If same, look for any rough edges on the needle plate and feed dog cover.
Beyond that, this does not sound like you are doing anything wrong. You should take your machine in for adjustment by an authorized technician. You should have about 1/2 to 1 full turn of the upper tension knob between too loose/ugly on back and too tight/breaking on the top.
Posted on May 12, 2009
  • radcal May 13, 2009
    I assume that anyone with this type of problem has tried a new needle. Needle manufactures may have a quality level of no more that 1 needle in 500 may be faulty to pass their standards. I have inserted that 1 of 500 and still had a problem while working on a machine and found that changing it the second time solved the problem. Closer inspection with magnification revealed a malformed needle that had come straight from a box of new needles.
    Inspira topstitch needles are not recommended for use in the 9" MegaQuilter. Please be advised that the owner's manual recommends the HLX5 needle ONLY.
    A topstitch needle will have a larger eye so it may help the machine sew if the hook timing or needle-to-hook clearance aren't quite right.
    I strongly urge you to stay with the HLX5 needle recommended by the manufacturer.
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
Why is my thread birdnesting? i am getting some thread that bunches up under my fabric. I have played with the tension changed needles, and rethreaded both top and bottom
bunching up under the material is loose tension of the needle thread
pull the thread out before you thread the needle and if it doesn't require a small amount of effort to pull then the thread is not between the tension plates or the tension plates are not being allowed to move closer together to add the tension
check that the thread is actually between the plates and not to one side of them
full tension adjustment should make it fairly difficult to the thread by hand
Nov 20, 2015 | Sewing Machines
Tension adjustment for denim with denim thread
If it is bunching and looping underneath, it's because either the machine isn't threaded correct on top or your top tension is too loose. For heavier sewing, your top tension should be set at 7 or 8.
Jan 12, 2015 | Sewing Machines
My bobbin thread is bunching up underneath. I have taken the bobbin out and the bobbin assembly out but it still is doing it.
Gayle,
In a sewing maching, for the thread not to bunch up, there are two thread tension tighteners. One each for the bottom and the top threads. The top thread tensioner is a nut that tightens or loosens the thread tension. The thread passes under this nut. While for the bottom thread it is two screws on the casing for the bobbin. These two screws hold a small strip of metal to the casing and the thread passes under this strip.
To be able to get proper tension on both the threads you have to strike a balance on both the top and the bottom threads. If the difference is not much then you can do with varying only one of them, usually the top one for ease of functioning.
Since you say that the thread is bunching uo on the bobbin side, ie, the bottom, means that the top thread is too tight and must be loosened. You cant do it in the first go. It may take you a few attempts to get it correct, so do not loose heart if it is taking time.
All the best.
Jan 27, 2011 | Kenmore 11101 Mechanical Sewing Machine
I am using black bobbin threaad with white needle
In my experience, I can adjust the tension on my older machines (like my Singer Featherweights so that the needle thread will not show at all on the underside of the fabric (and the bobbin thread will not show at all on the top)--but I've found it nearly impossible to get the same degree of control on my newer (computerized) machines. It always seems that there is a touch of the needle thread showing on the bottom and a touch of the bobbin thread showing on top.
I'm not familiar with the MegaQuilter but I'd just keep playing with your tension control to get it as fine as possible.
Robbie
Aug 01, 2010 | Husqvarna Viking 1
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
I can't get the thread tension correct on the bottom, even after adjusting the screw for the bobbin. Additionally, the thread frequently bunches up at the bottom. How do I prevent these problems.
If your tension is wrong on the bottom it is the top tension that is incorrect. Check the tension unit discs for dirt or obstructions stopping them from closing properly
Oct 13, 2009 | Singer 3116 Simple
Thread breaks right away and is all bunched up on the bottom stitch
ok u have a tension problem with the top of you system. also make sure that all thread is caln and no little pieces remain a cleanign kit should of come with your machinee. re thread both of the threads and pull on them there tension shoud be close to one another. use the top tensioner to adjust the top threads tension to amtch the bobbins this should fix the problem. also makle sure yoru not jerking around the material as the machine sews as it moves the neede and the bobbin catch tiomes gets off. use the stomp foot with the machine to help guide the cloth or abric. when you have to change directions. stop sewign and turn that fabric. this should also help prevent the bunching. please feel free to contact me at rdrteck@gmail.com for any further assistance.
Aug 11, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Bottom tension to tight
I found that sewing this type of fabric you should not have any pressure on the presser foot. and the top tension should be looser but note the tension before you adjust. and remember to make sure the needle is the right size for the fabric. and since wer are not to change the bottom tension because it always right?? then you may have to make the seam stitch longer good luck
Feb 23, 2009 | Consew 226R-1
The thread bunches at the bottom. It worked fine then one day in the middle of my sewing it bunched. I rethreaded. I adjusted bobbin tensions with the little screw and on top. Help
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Jan 31, 2009 | Singer 3116 Simple
Sewing Machines Logo
426 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
