No audio. no hiss on any input
I have a RCA PS35652 w/ a ctc169 chasis that has no sound. All speakers ohm out ok and I have no schematics. Is there anything common I can check.
  • 147 Answers
There may be a mechanical switch on the back input panel that turns the internal speakers off.
Posted on May 11, 2009
I have an RCA proscan tv, CRT type. My sound has to be turned all the way up to hear it. There is also a low hum whether the sound is up or down and does not change volumn, no matter if the sound is
The ctc169 was the workhorse of the RCA line being used in over 300 models----sounds like a possible audio output circuit---a lot of parts are no longer available and I would be careful having a shop fix a set this old.
YOU "might" be able to get around this with a surround sound system used with a cable box.
Dec 04, 2012 | Televison & Video
My rca model # p52721lv keeps blowing the fuse have replaced several times with the same results.
the problem with this tv is the main regulator , u can buy this repair kit by the chasis # or by the model # the best store to buy this unit is from union electronics , just look on the back of the unit and see what chasis it is ctc169 , or ctc197 or 95 , 95 and 97 are the same ,
Jul 18, 2011 | RCA P46924 46" Rear Projection Television
No audio
ok sound on the rca itc222 chasis comes ofd one curcit board. This board is called the small signal board. but before we get this replaced we have to elemate a few things. one check you audio setings and make sure the amplifer is set to internal. also you speakers could have blown. and the connectors to speaker unlikely be loose. If these items are elemanted then the small signal board. a item that only technicians can replace. they have special computer interface they use to download data from the old to a new board when they replace it
Jun 04, 2011 | RCA HD52W56 52" Rear Projection HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Hissing from computer speakers and they are new
Hello
A hissing sound indicates the speaker amplifier has no input from the computer sound card, check to make sure the speakers are hooked up to the correct port for audio out to the speaker input, the Audio output to the speaker is the GREEN mini RCA jack on the back of the computer.
Dec 30, 2010 | Bose Companion 2 Series II Multimedia...
Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear...
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Jul 07, 2010 | Audio Players & Recorders
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Sound went out on my RCA D52W20 rear projection HDTV while watching it.
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
