Need a motorized volume control or pc assy board
I need a motorized volume control or a whole pc assy board. Where cani find this? I am in Northern CA
  • 1,512 Answers
Hi mate
I have plenty here, but I am in Australia, I own a repair shop. Suggest that you go to your local repair guys, and ask if they have any wrecks of stereo equipment laying around that you can get the assembly out of. Is the easiest way to find what you need.
Posted on May 07, 2008
What the part no for main motor assy. The whole assy that needs to be replaced due to unusual grinding noise during paper run.
You cannot typically buy the entire assembly as one piece. You need to purchase the main motor and then all the related gears. There are companies out there that sell a kit with all the gears, look for one for the 5200 laserjet as they are the same.
Aug 31, 2016 | HP LaserJet M5025 MFP Printer
How can I get the console to work?
Heat sensor on motor is shorted out. Will have to replace thermistor or whole relay assy on motor sounds like. Not hard to do.
Jun 01, 2014 | Nautilus T914 Commercial Treadmill
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
I have a wave machine aprox 15 yrs old.If I manually spin the cd once or twice it will read and play but begins skipping on later tracks.Also volume control is sometimes problematic.Seems like it needs an...
Clean lense on cd pickup. Remove spin motor. Spray some WD40 in the bottom of the motor and connect 5 volts dc to motor and spin for a few seconds in both directions. The motor brushes need cleaned off. This works on most all cd players. Reinstall the motor.If this does not fix replace cd assy. Check solder connections on volume control. If ok replace control.I had one of these that i sold for $500.00 on Ebay. Even used there is a demand for this item.
Nov 20, 2009 | Bose Acoustic Wave (32022) 5-Disc CD...
Right brake light out 2004 Prius
Th other post is incorrect, the 2004 has LED brake lights that are part of the tail light assembly. you have to replace the whole assy. There are two screws that hold the assy in, they are both covered by white cable clips. The clips just pull off and then you can use a 10mm wrench to remove the nuts on the screws. My brake light stopped working and during the removal, the LEDs started working again, hopefully you will find the same situation as the LEDs are supposed to last for years.
Nov 29, 2008 | 2004 Toyota Prius
No Picture
Your LCD panel assy may have problem. Try to replace the scaler board or inverter board if you can find spare parts. Otherwise you may need to replace the whole LCD panel assy.
Nov 18, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Brother laser mcf-8440/ machin error 7a
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
Oct 26, 2007 | Office Equipment & Supplies
147 people viewed this question
