Question about Sharp LC-26D6U 26 in. LCD Television
I have no audio on my Dell LCD TV?
I have lost audio completely on LCD TV. Picture is perfect but no audio. How can I solve the problem? Is there anyway I can hook up external audio? Thanks in advance for your help.
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
I have a philips lcd tv model 42PFL7332D/37. Suddenly, the picture lost, but the sounds works perfectly. Can anyone help me to solve this problem?
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Nov 29, 2010 | Philips 42PFL7432D 42 in. LCD Television
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
No sound, picture perfect. w3706mc. works first 6 months
Hook an external Stereo Receiver (or surround sound system) up to the Audio Out jacks on the back of the TV... this should allow you to hear the sound again.
Hope this helps.
Nov 02, 2009 | Dell W3706MC 37 in. LCD HDTV
Sound proplem
its the audio amp, its fried and needs to be replaced. match the numbers up and purchase/replace boards, this will solve your problem.
Nov 28, 2008 | Dell W2600 26 in. LCD Television
Dell w1700
Make sure your in the right PC input. There is Analog PC for VGA and then Digital PC for DVI
Nov 16, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Dell W1700 17 in No picture, only audio
www.lcdrepair.us will repair that invertr for $49 or the whole monitor for $59 and has a large selection of DELL parts
Oct 25, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Sharp LC-26D6U 26 in. LCD Television Logo
204 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
