Question about Cameras
Canon Fax not completing transmission
I have a Canon 2050P connected to a Nortel Norstar phone system with an ATA (digital to analog converter). Some transmissions to specific numbers fail with the error code NG ##765. Transmissions to other numbers work fine. What does the error code mean?
When the fax is put on a direct line it transmits to these numbers fine.
How do correct this problem? (Other than the obvious of putting it on a direct line.)
  • Anonymous Feb 11, 2008
    I have the same problem. Anyone a suggestion?
    Thanks,
    Robert
  • 59 Answers
SOURCE: Transmission
Like on my earlier posts. VOIP is not reliable for fax transmissions. Actually dropping the tx and rx speed to to 4800 bps might help. Successful transmissions depends on your bandwidth of your internet service. VOIP faxing suffers from latency, distortion and packet loss errors.
Posted on Aug 13, 2007
cariandco
  • 39 Answers
SOURCE: I have a Digital Canon
There is a recall on your camera for problems with the CCD internal wiring. Go to this website for further info to send it in for the free repair:
http://forums.photographyreview.com/showthread.php?t=14939
I had the same thing happen to my Sony. If this is helpful to you, would you please rate this solution? Thanks!
Posted on Jul 18, 2008
marsrover
  • 682 Answers
SOURCE: When transmitting a fax the
there is a noise or static in your phone line try to put line phone filter from radio shack(279-151)-otherwise contact phone company.
Posted on Aug 03, 2008
SOURCE: need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: Unable to complete fax transmissions
The Analog line for your fax machine works best with a Trapezoidal Wave Form, but the line coming out of your adapter is Sinusoidal. Call Vonage support, get transfer to tech support and let them know you need a fax specialist, who will then update your account and change the waveform to Trapezoidal. That's how I got my HP Office 7860 Pro to work.
Posted on Jan 17, 2009
Does the Nortel Norstar 2501-03308-001 accomodate external microphones?
No sorry it does not.
For larger board rooms you need an Analog Polycom like the SoundStation2 Expanded w/mics.
It will require an ATA on the phone system to covert digital to analog.
Nov 27, 2012 | Lands Phones
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Can you use the nortel t7316e on a normal land-line..? I've noticed if I plug it in to a land-line that the top left red light flickers on and off, along with the microphone button bottom left and the...
You get around the problem by unpluging the phone and taking it back to wherever you got it, or going out and buying a CICS, MICS, or BCM cabinet to plug the phone into.
A Multi-line digital phone doesn't operate on a POTS telephone line.
Carl
May 28, 2011 | NorStar T7316E Corded Phone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
How do you log into a Nortel ACD Queue from an analog phone?
System level setup. One authorized phone and must be wired for two-way communication
Jun 29, 2009 | NorStar M7310 Corded Phone
Cordless phone
Just about any one will do IF you get an Analog Terminal Adaptor made for your system. The ATA requires programming in your system, so it's probably best to call a Nortel service tech.
Before some smart sould points out that Nortel has a digital cordless, remember that the "T" phone doesn't work on a Compact 308 box. Besides, an ATA and a $50 cordless is WAY less expensive.
Carl
Jun 27, 2009 | NorStar Meridian M7310 Phone
Is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Jun 15, 2009 | NorStar T7316E Corded Phone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Feb 22, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
