Question about Jensen XA2100 Car Audio Amplifier
The protection light is on
This amp was barely used, I took my time and did everything very carefully when it was unistalled. It was working fine, However when i reinstalled it in my new car the protection light stays on all the time even without the fuses. None of the circuts are burned, everything looks good, just no sound. If anyone can get me the wiring scematics please e-mail them to me. ThanksI have the same problem. The green power light only flickers intermittently.
  • Jensen Master
  • 5,807 Answers
is your amp already OK? i do hope it works
if still don't , try this disconnect all the speakers connected to your amp
disconnect whatever is connected to the line audio input
Are you having power now? if you turn it on?
if still protection light comes, you might have a busted amp.
if protection light doesn't comes good, your amp is OK
now to have a sound, reconnect speakers, watch attentively on the protection light, turn it on
if protection light doesn't appear rejoice, your speaker wiring's is OK
then next would be the input, here's comes the tricky part
what are you using RCA cables? if protection appears try to replace the RCA cord
if you are using the speakers wiring's of ypur car stereo maybe you need a line out converter to connect to your amp, or a1!:1 transformer to complete your setup, and your unit will surely work
hope this help, feel free to comment if you need further assistance, and dont forget to rate me well when it works, thanks for using Fixya! you're always welcome
Posted on Jul 03, 2009
  • 10,594 Answers
If you are looking for Jensen XA2100 car amp manual then click Jensen Support to download copy and if it is different model and brand, let me know to find it for you.
Hit "add a comment" button to reply / further query.
Thanks.
Posted on May 10, 2009
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
AMP GUARD
Amp guard is a protection circuit built o protect the output from short circuits. Please check your speaker wiring for shorting. Once cleared your system should work fine.
Jun 06, 2012 | Clarion DUZ385SAT Car CD/ MP3 Player
Kicker amp powers no audio all connections made properly
Is this the first time installing it or have you had it a while and it suddenly stopped playing ?
Aug 07, 2011 | Kicker Car Audio & Video
Amp 7541a amp was working fine, Took it out of one
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 18, 2009 | Infinity Reference 7541a Car Audio...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
VB101PK REV 13, AMP WITH SUBWOOFERS
was the amp hooked directly to the box? You probably rattled the power connections from the circuit board like I did on a PT 800 watt amp.but check amp fuses first.
Sep 15, 2007 | Visonik V117SX Car Audio Amplifier
Jensen XA2100 Car Audio Amplifier Logo
96 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
