Question about Home
Filter leaks water after use.
Hi. I have an AMERICH Whirlpool bathtub. I apologize up front if I don't know the actual name of the component that I've having problems with. My problem is that one of the round pieces (there are two of them next to each other on one side of the tub and I'm NOT talking about the jets) that look like some sort of filter because they have a lot of holes in the cover LEAKS FROM THE BOTTOM after I've used the tub. It drips every so often such that during the course of the day, I end up with dried water marks near there which I have to use CLR on to clean it up. The other one does NOT leak, so I thought it needed to be tightened so I turned it clockwise, but it still leaks. I can actually feel a space between the cover and the actual surface of the tub wall, so I'm still thinking that it's just not quite on right. I'm afraid to turn it counter-clockwise because I don't know if it's something that had to be put together before the tub was installed. Does anyone know what I'm talking about? Regardless, thanks anyway.
  • 3 more comments
  • workout993 May 24, 2009
    Hi, I called Americh and the technician explained that this is the "filter cover."  Because the piece inside is supposed to be at a slant, he thinks that maybe it's not slanted enough to cause the water to flow completely out so it pools near the cover and then drips out over time.  I tried tightening it up (before I read your response), but will try it again by pulling on it as you suggest.  Thanks for responding!
  • workout993 Jun 13, 2009
    Hi Ned,
    No, it's still leaking.
  • workout993 Jun 14, 2009
    Hello Again. Yes, I knew that "Plan B" would be the caulking trick, but I'm one of these tenacious people that just has to "really" fix it. Granted I'm not always successful, and do use Plan B, but I'm just not ready to give up on this. Something that I may not have mentioned before is that the filter cover doesn't sit flush against the tub wall all the way around. It's as if it's not on there correctly, but I originally took it all the way off and put it back on slowly in hopes that it would thread tightly completely around, BUT it didn't. I was going to take the cover off again, but I've forgotten which way I have to pull the small lever (inside the side hole) to "unlock it." I'll call Americh again to find out, unless you happen to know. This time I'll take a closer look at the inside of the cover and such to see if I see something strange, or whatever. Stay tuned.........Thanks
  • workout993 Jun 15, 2009
    Okay, will do. I'll put "Americh Problem" as the subject for my email so that you'll know it's me. Thanks again!
    Hmmm, my email bounced back saying that there's no such address. Please email me at workout993@yahoo.com and I'll send the pics. Thanks.
    President:
  • 3,433 Answers
I know what you are talking about, :). There is more than likely a large nut that holds that overflow in place behind the tub wall. See if you can put pressure on it, like pulling it out while you turn it clockwise The gasket is more than likely under the nut and pulling as you turn may get the gasket to grip the rough exterior of the tub and hold the nut still. then as you feel it snuggung up, put your palm over it as turn it as far as yo can tightening it up. See if that helps. the gasket probably shrunk or it was never properly tightened. If it seems to get looser, stop and go the other way. good luck.
Posted on May 21, 2009
  • 2 more comments
  • Ned C Cook
    Ned C Cook May 24, 2009
    Ok, I can go with what he said but regardless, It should not leak The water needs to go where it is suposed to go. Agree? What makes a good tool for turning those strainers with holes is a pair if needle nose pliars. You just need to avoid damaging the finish.
  • Ned C Cook
    Ned C Cook Jun 13, 2009
    Did you get it tightened?- ned
  • Ned C Cook
    Hi,again, well that wasn''t quite the answer we were looking forward ro hearing. Let me quote " The more interaction ascertained, the more we understand the object in question..".Now, the loose fixture is inaccessibleand therefore unaddressible **** to plan "B". We will address the effect and of the cause. Stop the darn leak and become the cause of ofresolve
    Are you ready? first determine what will fit in the gap between the fixture and tub surface. A dime, paper clip, anything that can be used to hold the fixture out with som pressure without distorting the tub wall. They will be removed later.Once evenly held outward, That tube of silicone you have in your hand ( clear) will have its contents liberally dispensed into the gap our spacers have creat between tub and fixture. Using your finger, force what you vcan into the gap.. Then, comfortsble in the adequare filling, remove our spacers. That done, withe the palm of your hand, left or right, your call, rotate the fixture abot 1/2 inch in one direction only. Enough to equal the width of your spacers. The silicone won't take long to set up so be patient. Not know what pressure the hose backside is imposing on the fixture makes it necessary to hold it flat agains the wall. You can confirm a uniform seal by the even bead forced out the edge of the fixture.. Any gaps, just finger force the silicone into thrm.. Use a rag tho wipe off any excess silicone one the fixr will hold itself in place. Now find a small screwdriver that will fit in the fixture holes and slip it in bout one inch into one of the holes near center and let it hang. This will counter any pressure the hose in back may be imposing.. Keep an eye on it as it sets up, especially on the bottom half. If the fixture moves outward, put light pressure but do not rotate. Once the silicone sets up thoroughly. give it a day while periodicacly checjing it, you can easilt clean up the mess you made with the silocone :) Kidding! The longer it dries the easier it is to just rub off woth your finger. Good luck . Oh, Make darn sue there are no access panels you could have utilized like trick removable boards or panels on the skirting. Sometimes they lift and the bottom comes out first. Enjoy.
  • Ned C Cook
    Ned C Cook Jun 14, 2009
    I do agree with you on doing it the righrt way. I too am curious to see why it wasn't seating in the first place. Yo mentioned a release lever So it is removable from the front? In that case it wouldn't be a good idea to use silicone. Do you have a phone camera? If so, take a pic of the evil object and send it ti me please..Co7196 @ yahoo.com
I changed the water filter in my whirlpool wrx735sddbm00 how do I reset control panel
We apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Refrigerator.
Feb 06, 2017 | Whirlpool Refrigerators
Where the filter is located
There are no filters on jetted bathtubs. There is a screen with dozens of holes located in the footwell of the tub. that is the suction cover. the water flows through that screen into the front of the pump and then out through each of the water jets.
US Parts Center
Aug 21, 2013 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Need an Americh Contura II drain stopper (plug) Ours no longer stays down
Americh does not make that part. You will need to track that kind of part down through your local plumbing store.
Rod
US Parts Center
Feb 03, 2013 | Americh Contura II Freestanding Biscuit...
I have a corner whirlpool tub and the pump is leaking water when it is on high. I am trying to find a parts supplier to repair myself
sounds like you need maybe pump union o-rings, part # o-49 or the seal might be leaking. If the water is leaking between the plastic wet end and the motor then it is definitely the seal kit which costs about $30 however on a bathtub most pump mfg have quit making replacement parts for them. You will most likely need a new pump in that case. If you can let us know what brand of pump we can assist you in repair or replacement.
US Parts Center
Aug 08, 2011 | Whirlpool Home
How do you remove and clean, or where do you find replacement jet knobs for americh jetted tub?
their jets un-thread counter clockwise. you will need to contact Americh directly. they will be able to sell you new jet trim.
Feb 19, 2011 | Americh Madison 2 6036 Bath Tub
My americh spa tub sounds like the motor is running but no air comes out of the jets.
Make sure the filter isn't blocked and that the air control is turned fully on.
Jun 02, 2010 | Americh Madison 2 6036 Bath Tub
Cracked housing to underwater tub light
I belive but am not positive that those lamp assemblies are required to be low voltage. In other words, there is no safety issue if water contacts the builb or wiring. Call Americh to verify. The lens ought to be easily replaceable so as allow for bulb replacement. Ask Americh.
Jul 11, 2009 | Home
I have an americh walk in tub equipped with whirlpool. water is leaking from the door.
The rubber seal needs to be replaced around the door. Some have two sets of seals, one on the tub and one on the door. Americh should have them in stock, or know where to get them.
Apr 15, 2009 | Home
Bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
119 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
