Question about Black & Decker Garden
My Black & Decker charging unit (681014-02) will not charge the cordless trimmer
  • luckygordon2 May 10, 2009
    The charger (681014-020 won't charge the cordless trimmer. Is there a fuse somewhere?
  • Lee Glascock May 11, 2010
    are u sure you are getting volts from charger?
SOURCE: CST1000 Black & Decker Cordless Trimmer/Edge won't start
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CST2000_TYPE_1
Part number #243614-00.
It's a microswitch made by Honeywell that costs about 5 bucks plus shipping.
The attached file has the schematic and parts list.
The CST2000 is well worth spending a few bucks to keep it going. Finding a local B&D authorized service center near you will even save you the shipping as they can order it for you.
Every other component is pretty dependable- the motor, battery, wiring, charging system, spool system- all built to last.
Only down side is you really only get 20 to 25 minutes of hard weedwhacking before you need to recharge. Of course, it's time for a cold beer in the pool by then.
Posted on Apr 24, 2008
  • 313 Answers
SOURCE: black and decker trimmer
can you specify what model
Posted on Jun 02, 2008
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
venexcsd
  • 1185 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Posted on Jun 01, 2009
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
Why does my Black Decker 12V cordless trimmer would not start
battery is probably dead... it may read fully charged but it cannot support the "load"... if you're only going to use something of that nature once. you really don't need it.
Jul 27, 2014 | Black & Decker String Trimmer Cordless 12"...
BLACK AND DECKER CORDLESS POWER PACK FOR 12 VDC SLA BATTERY #243215 for a Grass Hog Cordless Trimmer
Sorry, but I haven't solved any problem. I'm still waiting on the experts to solve my problem from June 16 on my trimmer not operating even with new fully charged battery. As for your replacement, I would suggest retail stores that sell trimmers, such as Home Depot, Lowes, Ace hardware stores or maybe B&D website.
Jul 07, 2014 | Black & Decker String Trimmer Cordless 12"...
Hi there problem with new black and decker 34V string trimmer
Generally all portable tool batteries slide into position until a click is heard alerting us that it is locked in position & just wont come falling out in use, look @ the manually closely & follow the steps ( you'll get it! ALSO note there will also be a way to release the battery once you have charge it......Good luck :)
May 26, 2014 | Black & Decker String Trimmer Cordless 12"...
How long do I charge the battery for 18 volt black & decker weed trimmer
put it on the charger and plug the charger into an electrical outlet ...
Jul 12, 2011 | Black & Decker String Trimmer Cordless 12"...
I have a cst1000 cordless trimmer. The recharging unit has failed. Do you sell a replacement that has the red and green lights indicating charging or charged?
Try this:
http://cgi.ebay.com/NEW-B-D-12V-VOLT-CST1000-Cordless-Grass-Trimmer-Charger-/200504468177?pt=LH_DefaultDomain_0&hash=item2eaeff62d1
If this has been helpful, please leave positive feedback. Thanks!
May 02, 2011 | Black & Decker Cst2000 12 - Volt Cordless...
The battery for my cst1000 cordless weekwacker will not charge. The fuse on battery case is OK. How can I be sure that the problem is not with the charging unit. How can I be sure that the battery is...
Test the charging unit with a voltmeter and compare the result with the stated output on the case of the charger. Do the same with the batttery. Neither is going to shock you and hurt you. B & D have a website where you can probably find out about ordering any available replacement chargers and batteries.
Oct 28, 2010 | Black & Decker String Trimmer Cordless 12"...
Batteries run down fast
if you are lucky you will get about 40 mins out of it but it will loose it charge when stored
Jul 26, 2010 | Black & Decker String Trimmer Cordless 12"...
CST2000 can't get the battery off when pushing the two release buttons.
Black & Decker didn't make it easy to remove the battery pack. You have to push both buttons in at the same time, while pushing the battery pack forward. It takes a little while to get good at it -- you have to hold onto the trimmer with the same hand that's pushing the buttons in, while pushing the head forward with the other hand.
If you're only taking the head off to charge the battery, you can charge it while it's still attached. The hole for the adapter is on the back of the head, so you can plug it in while it's attached to the trimmer.
Hope that helps!
Jun 17, 2010 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
69 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
