Question about Pioneer EQ-6500 9-Band Car Equalizer
What do the 2 blue wires hook up to? also on the back there is a switch nor-rev what is it and what does it do?
On the pioneer equlizer eq6500 what do the 2 blue wires hook up to? also on the back there is a switch,nor-rev, what is it and what does it do?
    Scholar:
  • 80 Answers
Blue goes to your head unit's blue wire. It switches the eq on when the head unit is switched on. It also gets tied into the amp's blue wire (if you are using an amp, and I guess you are since you have a passive eq...). The fact that there are 2 is just for conveinience I think (99% sure) If I recall one may have a white stripe, and the other none. If you want to be sure, with all power DISCONNECTED to everything, and the harness plugged into the EQ, use a multimeter to see if there is continuity (connection) between the 2 blue wires. Then you can rest assured they gave you a secind one just for a "pass thru" to your amps, but inside they are electrically connected, and are essentially the same piece of wire.
Posted on Jun 12, 2009
How do i hook up a pioneer deh 1700 to my car wire colors do not match
You are going to need a multimeter to find a permanent live wire the switched live and the negative for starters if you are removing an older stereo it might be easier as the switched live is normally to the red wire the yellow is permanent live and black earth from your pioneer you will have a blue that is sealed off that is the electric ariel or signal to an amp the rest of the wires ar plus and negative speaker wires.
Sep 16, 2014 | Pioneer Car Audio & Video
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
I need to no how the wires get hooked up
bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo2_bing.gif remote wire)
May 09, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
Watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Mar 03, 2009 | Pioneer AVIC-D3 Car DVD Player
Amp cd proble3m
i'm not entirely sure but i think that your only supposed to have the blue remote wire hooked up. but like i said i'm not sure. i hooked my amp up and somehow my remote wire shorted and fried my ignition switch so don't hold me to it, but maybe look into it. I think that you might have a constand power hooked up to a switched power cable for your amp so haveing the constant power to your amp, asied from your 12v at the battery, your amp might not even know when your car is on or off. hope this helps sorry for the open ender
Mar 14, 2008 | Pioneer DEH-1600 CD Player
How do i wire an equalizer without any wiring diagrams
1. bottom right( red wire 12 v dc on/off ignition switch)
4. top left( blue wire stereo remote wire)
I have a pdf photo diagram I made just e-mail me and ill send it to ya. hope this helps
Nov 15, 2007 | Car Audio & Video
Changed settings(LP to SP)
If there is still no sound, you probably hooked up the unit's wires wrong. Try switching the wires coming off of the back of your head unit so that the wire that is supposed to be connected to the amp turn on in your factory harness isn't connected to the antenna lead or something like that. I don't know what the Pioneer wires look like, on my Sony there are two blue wires, one with a white stripe on it and one just plain blue. The wire with the white stripe on is the one that should be connected to the amp turn on in the factory harness.
Mar 05, 2006 | Pioneer MEH-P5000 MiniDisc Player
Pioneer EQ-6500 9-Band Car Equalizer Logo
571 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
