Question about Canon P23-DH Calculator
Won't print/feed If I set the calculator to print, it tries to feed but just spins and the "E" shows up in the lower left hand corner of the display. I have tried to reset the calculator, but that doesn't seem to work. I can press the CE button and it will only spin the feeder and then automatically displays the "E" again and will not allow me to do any calculations. If I take it off of print and just to the ON setting, then it is fine and allows me to do calculations. Any suggestions before I throw it in the garbage?
  • jamiem398 Nov 13, 2008
    solution did not help me.
  • Mary Parisi Apr 06, 2016
    Here it is 9 yrs. later and having the same problem as in 2007. You'd think by now they'd have perfected it! How do you reset the calculator? Cannot take it off "Print". Batteries not the problem. "E" remains and device is locked.
Try removing the batteries in addition to reseting the calculator.
Posted on Nov 29, 2007
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
our calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Oct 22, 2015 | Canon P23-DH III 12 Digit Printing...
When I push the feed button, an E shows up in the left hand corner of the display.
The E is an indicator that the Paper Spool is EMPTY so either the paper sensor is defective or You have forgotten about a "bar" that the Paper must go through to be sensed. Or Your Feed motor has fed it's last. Best of Luck!
Sep 28, 2014 | Casio HR 100TM Portable Printing...
Printing Error
probably you need to feed the paper first, then plug it in.... try to read manual and check what E means in error messages.....
Jan 13, 2014 | Canon P27Dh Calculator
Are there spare part type belts for Sharp printing calculators?
Please contact your local Sharp service. Usually professionals have more extensive access to Sharp spare part databases.
Regards,
Juha-Matti Vihtanen
Oct 09, 2012 | Sharp Office Equipment & Supplies
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
How to feed the paper into the SPL-500 and how to set for printing?
You feed it from the back,(you will see an horizontal line) you're paper has to be straight cut, than you press the arrow on the left corner until you see it on the front.
Apr 20, 2012 | Staples SPLP500 Scientific Calculator
I want to know how to not have two additional 00's in the right hand corner of my DS 700 calculator
You're seeing an exponent, the power of ten.
To have the calculator not display this (unless the number won't fit into the display otherwise), press MODE repeatedly until the screen shows "Fix Sci Norm". Press 3 to select Norm.
If you need a manual, you may download one here.
Feb 24, 2012 | Office Equipment & Supplies
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
Canon P23-DH Calculator Logo
923 people viewed this question
old marine
old marine
