Question about Music
The loud speaker doesn't work .
My loud speaker do not work , he is fixed correctly
  • Frank Allik
    Frank Allik May 11, 2010
    you gotta be kidding...is that really all you got, MORE INFOOOOOOOOOOO brand size wattage how you powering it
  • 73 Answers
Hi there. With speaker disconnected. use an ohm meter to check the continuity of the speaker voice coil. (speaker terminals) Should be 1 to 3 ohm. If no continuity, bad speaker voice coil.
Thanks
Paul
Posted on Jul 11, 2009
Speaker shorted out
If you do not have training in electronics you can cause serious damage to yourself trying to fix this. You will need to take this into the shop.
Jan 17, 2014 | Harbinger Music
Need spec on Mckenzie loud speakers 12'' dual cone 85 watts rms
What\'s the question, are you asking about eyebolts, SRM 450 or McKenzie speakers?
Let\'s assume speakers. These are quite nice vintage speakers and were fitted in a number of units back in the day. Depending on the use they are going to be put to you\'ll need to find the dimensions of similar boxes for the same use and speaker size from (ideally) makers who used these speakers or something similar. It\'s going to be a bit suck it and see and will also depend on if you are looking to use an infinate baffle, sealed or vented enclosure.
Try Speakerplans com
Sep 23, 2012 | Mackie Pa-a1 Eyebolt Kit for Mackie Active...
How to fix a Samson XP40iw Speaker PA System
Have you checked the cables? If that doesn't fix it, you probably have a loose connection inside between the "mixer" unit and "amp" unit
Jul 23, 2012 | Samson XP40iw Speaker PA System
I have a hot spot VC, and the speaker still play, but they are very faint, and not loud at all. I checked all connections, and don't see any which are broken. Is it worth trying to repair, or should I...
Test the speaker itself. If the speaker is blown replace the speaker(s). If your has a volume control, I suspect the control may have blown. Test it with an ohmmeter. Inexpensive fix if it has blown.
Aug 26, 2011 | Galaxy Audio Standard HotSpot Monitor
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
Aug 14, 2011 | Peavey SP2 PA Passive Speaker
How do I fix the plastic jack inside the speaker? It seems loose, yet it connects fine, but still doesn't work. The wiring is fine.
Open the speaker and either secure the jack or replace it if it is broken... common problem when cables get tripped over.
Jul 19, 2011 | Peavey 00511800 Escort Portable Sound...
I have troubles with a to little speakersound i have checked the fuse and its okay its a new one for me this pmp5000 can you tell me i have 1000 watt speakers do they not play loud with this
These can develop around 500 Wattts or so into speakerss that are 4 ohm.
If your speakers are 8 ohm the max power to each is around 250 Watts.
The efficiency of your speakers may reduce the loudness . The power rating of your speakers really has nothing to do with the loudness, only the power that can safely be sent to the speaker.
Sep 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I am currently having problems with our PA System. We use a Behringer PMP3000 Mixing Board, with a Peavey PV115 Speakers. We can't get them to reach the volume these speakers are ment for. We would run a...
The speakers are 8 ohm so you can probably get near the 400 Watt per side when connected to this mixer. You don't need bridge mode to get this and I would recommend not using it anyway. Whatever you do make sure the speakers don't get disconnected when running at high volumes as you will arc out the amp in the mixer... I know this as I fix them... I have two PMP5000's that I repaired. Lots of work to repair...
The feedback is NOT the fault of the mixer or speakers but instead of something picking up sound from the speakers and sending back to the mixer.
The mic must be well in back of the speakers (say at least 10 feet) to avoid this or you need to use anti-feedback hardware to avoid the problem or highly directional close talking mics. Reverberation off walls can also get back to mics and cause problem. I was able to use a wireless Peavey mic which seemed to disrupt the phase enough to never get into an oscillation even when in front of the speakers.
Apr 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hi. When switched on the speaker makes a loud constant crackling sound. Nothing will work, no keys, stops, anything. Just a loud crackle!
This usually means that the speaker is blown. Try running through a different setup and see if it fixes the problem. Hope this helps
Oct 01, 2009 | Music
Music Logo
134 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
