Question about SonicWALL TZ 180 WIRELESS 25 NODE SECURITY APPLIANCE (01-SSC-6553) Firewall
I just bought a sonicwall TZ series, and when I plug the connection from my router into the Wan port , and my pc to lan1 port. I enter 192.168.168.168, browser never connects.
  • Sriram Srinivasan
    Sriram Srinivasan May 11, 2010
    please check the cable type. it should be cross over cable.
  • 79 Answers
You have to change the IP address on your PC to 192.168.168.x, where x= any number between 1 and 254 except 168
Posted on Jun 03, 2009
We have an SBS2011 behind a Sonic TZ-100. A router with DHCP enabled is connected to WAN of TZ-100. We need to block DHCP in the TZ-100, as the SBS shuts down his DHCP when it finds the DHCP on the router....
So I can understand better... You are trying to move DHCP off of your Small Business Server and on to a router that is connected to your firewalls WAN? I don't understand why you are trying to block the connection between your router and your server. Once you turn off DHCP on your server and remove the static IP on it, it should get a new address from your router.
Best, -Mind
If you need further help, reach me via phone at https://www.6ya.com/expert/clayton_0b2096930c0c699a
Aug 04, 2011 | SonicWALL TZ 100 0101SSC8734) Firewall
Two router dosnt connect with wireless
ISP cable connect to 1st router's DSL or WAN port then 1st router's LAN1 connect to 2nd router's DSL or WAN port through Ethernet cable.
Apr 05, 2010 | Belkin (F5D7230-4) Router (587009)
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Firewall as a switch
Yes, there isn't anything wrong in connecting any extra computers on the free ports. Go ahead and plug in your laptop. If it doesn't work, then its the best time to ask here. ;D
Dec 12, 2009 | SonicWALL NETWORK SECURITY APPLIANCE NSA...
Anybody, please help! I need it! Sonicwall issues
There are many reasons for your problem, make sure you have the Computer and Register PC are in the switch section of the Sonicwall - not in the WAN port. The router should allow traffic to flow by default. Check the Operating system and turn off any firewalls, the router will take care of that.
May 03, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to switch over opt port to wan port in sonicwall
In order to do this, you will need to order the sonicwall OS enhanced. You can do this from your mysonicwall.com account.
After you upgrade the firmware, you will have a network load balancing option. you can then set the primary and secondary connections and use the active/passive failover option that is provided.
Jan 10, 2009 | SonicWALL Content Filter List (01SSC2733)
Need to connect router to deck top.comp.
This might work for you. Now to go in and configure the router thats something totally different.
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
How do i connect up my router
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
SonicWALL TZ 180 WIRELESS 25 NODE SECURITY APPLIANCE (01-SSC-6553) Firewall Logo
362 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Alun Cox
J John
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
