Question about GE Dryers
Dryer taking too long to dry clothes
GE model #VD952K
  • 532 Answers
Check the exhaust tube for blockage,doesnt cost anything but 20 minutes of your time,after that if its gas then there is 2 magnet coils on the gas valve that may need replacement which are about $15.00 for the set,after that could be the timer which is more expensive(not sure of the price amount)
Posted on May 10, 2009
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Clothes dryer
Hi, The most common solution to this is to make sure the 4" exhaust is clean all the way out.
Is this a gas os electric dryer?
Vic
May 10, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer takes many cycles to get clothes dry
While researching my problem I did find that the dryer vent hose could be partially clogged. The hose should be short and horizontal.
Mar 25, 2009 | GE DBSR453EBWW Electric Dryer
GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Feb 27, 2009 | GE DBLR333EE Electric Dryer
GE Dryer model DBXR463EDIWW
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
Dec 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
90 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
