I bought a samsung dvd player today but when i insert a disc it says cannot load, wrong region! After consulting the manual it explains how the dvd player and disc must match for region number. i checked the number on the dvd player and the disc and they do match. Both 2. Why is it still not working??
  • 1 more comment
  • b_langridge May 11, 2009
    it is a samsung DVDH1080R DVD Player
    Many Thanks
    Thank you, but none of the models mentioned relate to my dvd player.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    tell me ur model u can make it region free
    President:
  • 1,223 Answers
Kindly see these sources
http://www.regionfreedvd.net/player/samsung.html
and kindly rate me WELL !
Posted on May 11, 2009
  • Shoaib Rais
    Shoaib Rais May 11, 2009
    u see any of this will work there are not that specific but pls try some or all of them will work , it is same u will see resemblence in the code entry procedure
    so take ur time and try one by one
My Samsung smart tv & my dvd/bluray player recorder I bought at same time. Haven't had blurays til now & wont play at all. Rental ones did now I've bought my own & they don't play!Not tech minded.HELP
Each DVD player is assigned a code for the region in which it's sold. For example USA/Canada are Region 1 players. DVD players will refuse to play discs not coded for its specific region. In effect, this means that a DVD purchased in one country is normally unreadable on a DVD player bought in another region.
If your rental DVDs work in the player then there is nothing wrong with your DVD player. If you have purchased DVDs that do not work the problem is with the DVDs you have, not with the DVD player.
Jun 04, 2016 | Samsung Televison & Video
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
I have a samsung BD c5500 bluray player. When I try to play movies it says mismatch disk and region code. How can I fix this?
Providing that you have a legal DVD player that is meant to play discs in this country and that you have bought a legal disc (not an illegal bootleg copy) you might need to do a firmware update on player.
If player has internet connectivity you can do it directly on player - it should be a menu prompt to update firmware
if no internet connection is available on player you will need to contact Samsung and have them send firmware update to you on a disc and load it that way
If either disc or player is a bootleg or grey/black market purchase than that is the issue
Players will only play discs from the region they were made to work in
USA is region 1
good luck
Mar 13, 2011 | Samsung Televison & Video
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
Unlock dvd player to play all dvd regions
I bought today a Philips HTS 8140 region 4 and i use this solution
1. Abrir a bandeja do aparelho / Open the tray
2. Aperte a tecla DISC / Press DISC buton
3. Digite o código 99990 / Insert 99990 code
4. Feche a bandeja / Close the tray
Jan 12, 2009 | Audio Players & Recorders
My samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Feb 09, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Sampo
POWER ON
OPEN/CLOSE
Key in 3,3,0,8,8,0 on the remote for region-free
OPEN/CLOSE
POWER OFF
Oct 02, 2007 | Sampo DVE-612 DVD Player
"wrong disc" message
Since the device is new, I suggest that you take it back to the shop, ask for a replacement and check it while in the shop to make sure its working. This is assuming that you made sure that you're trying to play the correct format discs. Consult the manual on which format DVD's it can support. Its multi-region so that can't be the problem, but its possible that you're trying to play other unsupported formats. Try also playing other discs - audio discs, DVDs, DIVX etc... make sure the disc isn't scratched badly. But the bottom line is you shouldnt have problems on the first day, take it back. Good luck!
Jan 25, 2006 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Electro Med Services...
