Question about Garden
Speed adjust I have a Rally 20" push mower with a Model 9s502 Briggs and Stratton engine and I want to speed up the engine but can't find any adjustments. Please help, Thank you, Larry
  • 351 Answers
At the front of the mower there should be a metal plate, usually black which has a hole in it, you should be able to see a screw in the hole which will increase the revs of the motor
hope this helps
Posted on May 11, 2009
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
How do I adjust a throttle on a briggs and stratton engine?
If it the simple handle type throttle cable..push it to full tbottle and follow the cable to the carb..you should fund a small clamp that hold the cable in position..jus loosen and adjust the carb throttle to full throttle and tighten..then push it back to idle to make sure it Idles if not adjust the clamp again until you reach both throttle and idle..good luck..
May 17, 2014 | Briggs & Stratton Briggs Stratton...
I need an engine diagram to help me put my lawnboy 10642 briggs and stratton eng ine back together
Go to partstree.com and search your model number and you will see an exploded view. Thank you for using fixya.
Aug 22, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Need manual for Murray 20" cut 3.5 hp Classic push
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
Jul 03, 2011 | Briggs & Stratton Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I can push the handle all the way in, but I get very little speed from the mower.
Your throttle cable likely needs adjusting.
It should be fastened on the engine with a screw. Loosen that screw and adjust while engine is running then tighten Keep fingers away from underneath while engine is running.
Oct 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Rally ride on lawn mower not starting. briggs and stratton 12 hp engine. battery fully charged but engine not turning when ignition key turned
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
May 03, 2010 | Garden
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
171 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
