Question about Pioneer EQ-6500 9-Band Car Equalizer
Neeed to know the wiring
On the pioneer equlizer eq6500 what do the 2 blue wires hook up to?
  • 578 Answers
REMOTE POWER SOURCE IS HOOK
Posted on Aug 07, 2009
I put a Pioneer AVH 1400 DVD in 06 solstice have it hooked up working but no sound through speakers I have hot ground remote and speaker wires hooked up what other wires have to be hooked up 4 sound
If the car had an amplified sound system prior to removal you will need to turn on the factory amp. You need to hook up the blue wire with the white stripe. You may have a dedicated wire that you need to hook it to or you may have to hook it directly to the 2 blue wires for the power antenna. Now you may not have a power antenna but hook them up anyway. If that doesnt work you have a dedicated amp turn on wire. If you find that and it still doesnt work check your fuses for the amplifier with a digital multimeter. Replace any blown fuses that you cant find
Apr 17, 2016 | Pioneer Car Audio & Video
I NEED TO KNOW WHERE TO HOOK UP WIRES FOR PIONEER DEH-15UB
Red wire need to be hot just when your key is on and the yellow wire is you auxiliary need to be hot all the time that is your memory and than you will have 8 wire they all have their pairs that is speakers and your blue wire wich is remote and amp if you have one
Feb 26, 2013 | Car Audio & Video
I am hooking up a pioneer super tuner d. It has an illusion wire and a positive dimmer wire. What are these wires for?
You need a hot wire red and a ignition wire yellow and ground for power. Hope this helps plus the speaker wires. Hooked up. If using a amp then you would use the blue wire for a remote wire to amp.
Jun 24, 2011 | Pioneer Car Audio & Video
Neeed to know what wire go to what on a 1994 ford tempo trying to hook up kenwood model kdc138?
1994 Ford Tempo Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange any more info let me know go to http://www.tintingbyfredjohson.com to email me
Dec 22, 2010 | Kenwood KDC-138 FM / AM Receiver
I HAVE A NEW PIONEER AVIC-710BT THE AM/FM WORKS FINE HOWEVER WHEN I INSERT A CD NO SOUND FROM THE SPEAKERS
chances are, you hooked up the wrong blue wire... the power antenna wire (blue) is hooked up to the amp turn on wire... so while the radio is on its sending the signal to the amp to play and when the cd player is on it shut off... swap the blue wires and everything should be dandy...
Apr 29, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
What are will hook up to my power antenna
there are 2 wires you can try, the blue wire or blue with white, 1 will give a constant 12volts when the radio is turned on the other will give 12 volts for 15sec the go to 0 volts
Apr 25, 2010 | Pioneer DEH-1600 CD Player
No sound from new stereo
check the speakers in the rear deck, in the rear hatch or trunk, often the two wires that come out of the speaker touch if that happens it will short out the speaker drivers in the radio most times no permanant damage will occur. separate the wires so they do not touch,or touch the metal speker base, that may not be the problem but its a start..
Oct 16, 2009 | Hyundai Motor 1998 Accent
What do the 2 blue wires hook up to? also on the back there is a switch nor-rev what is it and what does it do?
Blue goes to your head unit's blue wire. It switches the eq on when the head unit is switched on. It also gets tied into the amp's blue wire (if you are using an amp, and I guess you are since you have a passive eq...). The fact that there are 2 is just for conveinience I think (99% sure) If I recall one may have a white stripe, and the other none. If you want to be sure, with all power DISCONNECTED to everything, and the harness plugged into the EQ, use a multimeter to see if there is continuity (connection) between the 2 blue wires. Then you can rest assured they gave you a secind one just for a "pass thru" to your amps, but inside they are electrically connected, and are essentially the same piece of wire.
May 10, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Pioneer EQ-6500 9-Band Car Equalizer Logo
414 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
