Question about Hitachi Televison & Video
Help needed to adjust the picture size.
The picture is too big. The tops of the heads are cut off. When we watch baseball the information box showing the innings, outs, etc. does not show up and I don't know how to adjust the set to make the picture smaller inorder to show the picture we should be viewing. It looks like it is zoomed in or something. I tried the "aspect" control but it still doesn't fix the problem. Any suggestions?
  • 431 Answers
I can only suggest that you read the manuel it should give you guidelines for this problem .. if you do not have the manuel you may be able to download one in PDF form from the manufacturers .
The other slight possibility is if the projection unit is a rear free standing type it may have been pushed closer to the screen some how perhaps during a furniture reshuffle I have had this happen before and people dont think of it untill the engineer ask's ? .. regards Vortash
Posted on May 10, 2009
The screen does not show the whole picture and it is cutting the top or the bottom of the picture
If the button on the television remote that is meant to adjust the picture size i.e. wide or format/view mode button is not working then you need to adjust your cable box. There is a hd zoom# button on the cable remote towards the bottom that will fix this or sometimes the button will say format or aspect. You may have to go into the cable box's settings and choose crop 1080i or some other picture format setting that will keep the heads from being chopped off. You may have your cable box on the wrong resolution for your television. Your cable box may be connected to the television in two places, and your television might be on the wrong source/input for hd viewing.
Sep 20, 2011 | Televison & Video
Watching a baseball game the stats on the top of the screen are half hidden. How do I adjust the picture size?
chang pix format it will be like full zoom 4.3 16x9 if you use a cable box check format for cable box also
Oct 10, 2010 | LG 32LG30 32 in. LCD HDTV
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Oct 14, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
The picture is too large for the screen
If you have a cable or satellite HD box see if there is a ASPECT button or look for an aspect/picture size buttn on your TV's remote control.
May 06, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Televison & Video Logo
91 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
