Question about Kenmore 62802 Electric Dryer
Kenmore 90 Series stopped running
My dryer stopped and won't turn on.  Nothing happens at start switch when pressed.  I opened back gray panel but see no fuse, only three wires coming off the main electrical connector into the machine from the power cord.
  • deb108 Oct 12, 2007
    Are there any other suggestions out there?
  • 5,911 Answers
The problem you are having may be caused by a blown thermal fuse.  You can check by performing the following steps:
1. Unplug the dryer.
2. Remove the back panel.
3. Look for the thermal fuse which is usually white or black in color (plastic) and mounted on the air blower housing on the left side of the dryer (viewing from the back).  There will be 2 wires attached to it.  The other device mounted near it is the operating thermostat, is thicker in shape, and may have 4 wires attached to it.  The dryer will usually still run if the thermostat is bad, but won't heat properly.  The thermal fuse should read a short (or fairly low resistance).  If the fuse is blown, it must be replaced.
Keep in mind, if the thermal fuse has blown it is usually for a reason.  You could have an overheating problem in the dryer causing the fuse to trip.  If you haven't cleaned the dryer vent ducting, or air blower housing any time recently, it may be worth an inspection to verify you have good air flow and no clogs.
If the thermal fuse is good, carefully plug the dryer back in (with the rear panel removed) and take a voltage reading across L1 and L2 (Red and Black) wires in the rear at the terminal block.  This is where the power cord terminates at the dryer.  You should get a reading of 220 to 240 VAC.  If you aren't getting the proper voltage, check the voltage at the wall receptacle.  You could have problems with the receptacle and/or power cord.
If the voltage at the terminal is good, carefully remove the back of the console on the top of the dryer and look for a wiring diagram.  All dryers should have one inserted inside the machine somewhere.  On this model it is usually placed inside the console.  Verify you are getting voltage to the timer and/or start switch.  If you are getting voltage to the timer and/or start switch, the problem may be the timer or associated wiring.
Post back with comments if you need further assistance on how to troubleshoot.   I hope this helps.
Posted on Oct 12, 2007
  • 188 Answers
1 st check all power socket......
2if power sockets rae ok then check out cable it have any cut ....
3if every thing u check ed is ok then emidiatly contact ur dealer for  extra support.
best regards & best of luck..
Dryer won't stay on when let go of start button.
One of two things is wrong. Either the start switch has gone bad or the start winding in the motor is failing to switch over to the run winding. You'll need to get a multimeter and before starting unplug the dryer. Once thats done, get behind it, remove the back cover to the control panal and disconnect the two wires that are connected to the start button. With your meter set for checking continuity, place a meter lead on start button pins where the wires were connected, one lead on each side.With leads in place have someone press the start button, if continuity shows when pressed and stops when its not, the button is good and the motor is bad. Personally, I think the motor winding has burnt, and the motor should be replace, but I also think that the start button should be changed as well because its in direct series with the motor, and could have taken damage that may not show up until further down the road, plus its an inexpensive part.
Apr 28, 2012 | Kenmore Dryers
I have a Kenmore 80 series 110.70812990 won't start!
first ceck the door switch,if not thatunplug remove back and check the long white main fuse to your left-mike
Feb 24, 2010 | Kenmore Dryers
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series Model # 66912691
most of the time if a dryer does nothing it is the door switch done bad or the mine fuse behind the back panel on the blower box,let me know more-mike
Mar 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryer just quit
There is no reset switch and there is no fuse inside the console.  I posted comments to your solution under the premium problem section.  I believe you could have a bad thermal fuse which is located in the rear of the dryer.  I left instructions for you to follow.  Let me know if you need further assistance.
Oct 12, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62802 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
