Question about Black & Decker Garden
The charger doesn't charge the cordless unit
Charger will not charge unit. Is there a fuse somewhere?
danny_murray
  • 55 Answers
SOURCE: Charger not charging
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: Cordless vacuum WESTINGHOUSE WST1600A - problem with charger.
http://www.download-manual.com/shop/Westinghouse-c-145.html
Posted on Jan 16, 2009
  • 142 Answers
SOURCE: not charging
try wiggling the battery around and see if a light flashes
also look and see if a light flashes when you plug it in
i'm about 98% sure it's the charger
Posted on Oct 20, 2009
airnailer
  • 109 Answers
SOURCE: Black and Decker HP122 cordless drill. Battery
most likely this order: battery , charger , drill
Posted on Dec 03, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
The car charger in my 2003 honda accord doesn't work
Could be the fuse for the cig lighter or the fuse in the charger.
Will the charger work in a different car ?
Apr 15, 2013 | 2003 Honda Accord
18 V Ni-Cad charger repair
From what I've seen.....usually when Lithium batteries won't charge it's because they lost too much of there charge. As soon as a Lithium battery shows signs of weakness they should be charged. But to answer your question most chargers do have a fuse soldered to a circuit board so yes it's possible to be a fuse but not usually "simple".
Jan 01, 2013 | Porter Cable PCL318IDC-2 Tradesman 18V...
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
I've borrowed a friend's Garmin for a trip and when I use the car charger, it doesn't display anything. Once I disconnect, it becomes visible again. I'm going on a long trip and worry. ...
Assuming there is power at the cigarette lighter jack - turn the Nuvi off - then connect the charger. It should display charging battery or charging complete.
If nothing - does it charge with the wall charger? If so check the fuse in the car charger - it's usually in the tip of the charger which can be turned to get the fuse out.
Jul 05, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Wagner cordless drill ,the charger is not charging the drill the orange light keeps flashing
If the charger is no longer working, then, take another
charger to charge the battery of your Wagner cordless
drill. If it charges, then, you have to replace your charger. It is already defective.
Nov 22, 2009 | Drills
Garden Logo
122 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
