I have a Sylvania SRT2227S with video rollover a the top of the screen.
  • 431 Answers
I am unfamilliar witht this model however it appears to sound like a Cathode ray tube Television , roll over is caused by a fault in the vertical frame output stage if it is an old Hybrid set it will probably be a vacum valve that controls this ( however havent seen this type in 20 years all transistor and intergrated circuit outputs now ) and repair should be undertaken by a qualified engineer . if an engineer is not available then someone with electrical knowledge and safety precaution training as the insides of these type of televisions generate lethal voltages at several points in the system . The coils around the tube base are the deflection controlers and they control the size and shape of the picture depending on the voltages and positioning of the screen mask's to shape and stabilize your picture . Any one touching these without the correct tools may damage the set further by distubing the convegence settings , in short I suggest that this is a job for a trained TV technician ... Regards Vortash
Posted on May 10, 2009
Model srt2227s
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 05, 2014 | Sylvania Televison & Video
Lines at the top of screen
Check and replace all the electrolytic capacitors at its vertical output section. The lines you refer here are technically called, vertical retrace lines, and are mainly due to capacitors itself. Check all the solder terminals of vertical output IC for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder to each point. When replacing capacitors stated above, replace them all at one time. There will be 5 of 6 numbers of them, the most, and wont cost more. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 09, 2013 | Televison & Video
Sylvania SRT2227s how do i set up a dvd player without the remote?
call 888-290-0871... mon through fri 8- 5:30!! it wont work it needs the original factory remote.! it sucks I know.. i just had to order one! universals do not work!!!! the cost is between 12 and 20$! good luck!!
Oct 23, 2010 | Televison & Video
Can the sylvania video/mp3 player-smpk8854b be reset?
if you can navigate the screens you can, tap settings,default set, yes.
try reset on top of player if its acting up.
firmware is not available for these players.
Nov 24, 2009 | Sylvania Audio Players & Recorders
Sylvania smpk8854. says games and plays videos.
you should take it in to a repair shop to get your touch screen cheked and if it comes down to it take it back
Nov 17, 2009 | Sylvania SMPK8854 Digital Media Player
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
Rollovers and video capabilities on frontpage
Inserting a video:
http://support.microsoft.com/kb/825508
Roll-over is called Mouseover:
http://support.microsoft.com/kb/884735
Nov 24, 2008 | Adobe Photoshop 7.0 for PC
Remote Coontrol
Check your remote manual (or the maker's website) for a 'scan' mode, which will let you try each code combination stored in the remote.
Be advised though that not every remote will have all the functions available from your new acquisition.
Apr 09, 2008 | Universal Remote Control URC4021 Universal...
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Sylvania 6842PE picture is 'zoomed in'
There is a button labeled "ZOOM" on your remote control, press it to cycle the ZOOM settings.
Nov 17, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
