Question about Sony Audio Players & Recorders
Rear S-Air speakers cutting in and out
Hello all,
I have a Sony Bravia HDX-576WF home theater system, with the S-Air wireless speakers and receiver. The wireless speakers keep cutting in and out. This happens regardless of what mode the system is in (Pro Logic, Multi). When the speakers cut out, the green LED on the front of the wireless receiver flashes on and off (which I believe means it is looking for a signal; it glows steadily green when the speakers are working). The switch on the back of the S-Air receiver is switched to "A", the only switch position in which the speakers will work.
Is there anything I can do to fix this problem? The S-Air receiver is only about 10 feet away from the system, and is in clear view (not buried by magazines, fast food bags, cats, etc.). I have placed it low, on an end table, and high, on a bookshelf, and the problem still persists.
Any help would be greatly appreciated. Thanks! I've got a similar problem. My S-Air surround speakers work in sat/cable mode only when I'm NOT on an HD channel (I believe is said 480i or something). When the cable box hits an hd channel it changes to 720 and the s-air stops working and green light blinks. The FM and AM tuner mode has the same issue UNLESS I turn the tv off then the s-air picks it back up and the surround speakers work again. DVD mode cuts out the s-air speakers too.
Sony support wants me to ship the thing back to TX to get it fixed. I would love to avoid this if all possible.
Any ideas would be greatly appreciated.
  • 3 Answers
SOURCE: infinity tss-1100 sub problem
hey buddy, I have the same system, and although I haven't experienced it on this one, I had the Harman Kardon equivalent to the TSS-750, and the sub did this same thing. It was a loose RCA connection, and, as I was well outside of warranty, I took the amp out of the back and just re-soldered the connection myself. It now functions flawlessly for my bedroom setup. I hope you get it all worked out on your system! I can't imagine using this awesome system without its deep notes!
Posted on Feb 14, 2009
SOURCE: Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Posted on Feb 22, 2009
  • 336 Answers
SOURCE: I have purchased a samsung 46 inch LED television.
You may have to go into the bose setup and select optical in for that particular input. Check your user manuel it should say in it.
Posted on Aug 16, 2009
SOURCE: Remote Control Control Codes
has anyone solved this problem???
Posted on Aug 21, 2009
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
The S-Air receiver for this unit DAV-HDX576WF cuts out when i bring it upstairs. Ive read that it should go alot farther. Please Help!
Most of the distance mentioned in ads and manuals are direct line of sight. As the number of walls between the transmitter and receiver increase the range keeps dropping drastically. Its not the distance but the obstacles that come in between that matter.
Aug 22, 2011 | Sony BRAVIA® DAV-HDX576WF Theater System...
I bought a new Magnavox LCD HD TV and need an audio system
Their not showin it on this site, but go directly to the Sony site and look up the Sony Bravia DAV-HDX 285 system. Its an awesome inexpensive system (compare to other systems). Features everything you need including the reciever and 5 wireless speakers and 1 wireles woofer. I love the wireless stuff because your not trying to hide wires, it looks nice, and its easy to install. Hope this helps.
Oct 30, 2009 | Audio Players & Recorders
MY S-AIR SPEAKERS ARE NOT WORKING
Are the wireless turned on and configured to work?
Check settings and batteries.
Maybe it would be best to run wired?
If not try what I have said before.
Hope this helped
-Ryan
-Please Vote if this helped.
Feb 18, 2009 | Sony Bravia DAV-HDX576W Theater System...
Feb 16, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony bravia wireless speakers won't pair? ANy answers?
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
Dec 26, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
680 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
