Question about Hayward SAND FILTER, PRO SERIES
Hayward vari flo filtering system
Knob is on backwash and is filtering into the pool (filter pulls water out of pool)
  • 78 Answers
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
Posted on Apr 22, 2010
  • Deedra Semones Jun 15, 2013
    Has been working correctly but now isn't. Nothing has changed on plumbing?
Hayward vari flo valve
Does it filter? Does the pump have full prime? I'm not clear about how when the valve is put in the backwash position nothing happens.
Jun 15, 2013 | Pool & Spa
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
What i she sequence when backwashing---Backwash - Rinse - Wash ? I have a Vari Flo
Backwash until water in the sight glass is clear, shut off the pump and change the valve setting to rinse, turn the pump on for a couple seconds and then back off, change the valve setting to filter and return to normal operation. NEVER move the valve handle while the pump is on.
John
May 05, 2011 | Hayward SAND FILTER, PRO SERIES
Too much pressure in sand filter
IF your filter is really the EC75 that's listed in the heading, then it's not a sand filter, its a DE filter. See link to manual:
http://www.haywardnet.com/products/Manuals/pdfs/Manual257.pdf
If this is not the correct number, then you can find the correct manual on their web site. So did it have a multi-port valve already? or did you install it. IF it is a sand filter then there is something plugged inside the filter (small fingers on spider?) If that's the case locate the manual on their web site and follow the assembly insturcitons.
Jul 20, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
Our sp0710 vari flo multiport value in the filter position is letting the water run out of the filter like it is in the backwash position
SHUT OFF PUMP TAKE HANDEL AND MOVE TO DIFFERENT POSITIONS TO SEE IF THERE IS CHANGE THERE IS A WHEEL UMDER HANDLE THAT MAY BE OUT OF POSITION TRY A COUPLE OF ROTATIONS START PUMP AND THERE SHOULD BE A CHANGE NEVER TRY TO MOVE HANDLE WITH PUMP ON
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Pressure gauge at maximum
Do you have a 'Earth' (dirt) filter system.
If - yes - these get block v-quickly (v-quickly!)
* Try to minamize 'vac'ing your pool, (or clean filter each time after 'vac'ing Or Vac on waste setting)
* Use pool skimmer box filter socks.
Jun 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward SAND FILTER, PRO SERIES Logo
439 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
