Question about Asko D1716 Built-in Dishwasher
Machine turns on but no water come into diswahser
I have an Asko D1716. It powers on, and seem to work through the cycles but there is no water coming into the machine. The soap is still dry? Any suggestion.
Here's the kicker... I am planning a kitchen remodel with a new dishwasher so really was hoping to find a DIY fix.
Any suggestions?
  • 72 Answers
Ensure there are no kinks in the water feed when you push it back into position and also ensure water is turned on.
Posted on Dec 27, 2009
Water is not coming into the machine when it is turned on
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 20, 2011 | Asko D1716 Built-in Dishwasher
DOES NOT FILL WITH WATER. TRIED DIFFERENT CYCLES.
Here is a tip that will help you to find out why water will not come into the dishwasher...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 22, 2010 | Asko D1716 Built-in Dishwasher
Our Asko D1716 dishwasher functions to fill and empty but the pump which causes the sprayers to rotate and distribute the water does not function. The local appliance repairman diagnosed the problem as a...
Hi !
Got a D1706 ( in 2002 ) paid $1000 and as os April 2010...same problem as yours, I will trow it away ( dishwasher ) and will never buy at such cost. I'll get a GE or LG.
Stupid Sweden dishwahers
Nov 16, 2009 | Asko D1716 Built-in Dishwasher
Water does not drain from machine at end of cycle
it sounds like the out flow is blocked some where on the front of your machine normally down the bottom there is a door open it behind should be a tap/plug type of thing turn it but put something underneath to catch the water this takes time when done take the plug out all the way have a look at the fan behind it will probably be blocked
Aug 21, 2009 | Asko D1716 Built-in Dishwasher
Water is not entering machine when turned on
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Aug 13, 2009 | Asko D1716 Built-in Dishwasher
Is it OK to attach a hot water feed rather than cold water.
All dishwashers are suppossed to be connected to hot water. Who connected yours to cold water and why? Doesn't make any sense. Definately change it over to hot water feed.
May 14, 2009 | Asko D1716 Built-in Dishwasher
Asko D1716 won't start
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
175 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
