Air not Cold
The air is not cold in my 2003 Dodge Stratus. The heater works fine. It does blow air, just not cold air. Help, I am hot.
  • 744 Answers
It could just be low on refrigerant. There are safety controls that protect the system in the event of low charge. Unless you are familiar with this kind of work and also have the appropriate tools, it's usually best to take the vehicle to a competent A/C repair shop.
Posted on May 10, 2009
How do I fix the heat
You have one of two problems. The heater core is plugged /
restricted or there is an inoperative internal blend door motor problem. Start the vehicle and let it reach operating temperature. Feel the hoses under the hood that go into the heater core. They should be close to the same temperature. If one is hot and the other luke warm/cold.... the heater core is plugged/restricted. If both hoses are near the same temperature, suspect a defective/non operational blend door motor that controls heat/cold/airflow attached to the heater box assembly
Dec 21, 2015 | 2003 Dodge Stratus
I have a 2006 Dodge Stratus and my radio goes on and off while driving and also the heater blows hot air and when the radio goes off the heater blows cold air.. what could this be someone help me please
This could be a wiring issue. The wiring of these components are found under the dash and at some point their wires come close. Check for loose connections or exposed conductors.
Sep 29, 2011 | 2006 Dodge Stratus
My 04 dodge stratus heater/defrost doesn't work very good. You can take the dash control unit out and mess with the wires on the back of it and it will blow hot air for a little while. I use to do this...
Sounds like the control unit or wiring (since you could mess with the wiring to get it working). The controls aren't controlling the dampers in the ductwork to control hot/cold, etc.
May 19, 2017 | 2004 Dodge Stratus
2001 Dodge Stratus SE Heater
Replace the Blower Motor Resistor.It will be located in or near Blower motor box.
Jan 18, 2010 | 2001 Dodge Stratus
My heater won't stay hot. 99' Dodge Stratus
sounds like you might have a heater core problem, you also might want to check the thermostat. it may be stuck open
Nov 22, 2009 | 1999 Dodge Stratus
2004 Dodge Stratus heater only blows cold air? I just put coolant in because it was empty. What else should I do?
my 2003 dodge stratus. when I turn on the heat it blows cold and some times it works but not most of the time it just blows cold my car dosent over heat the rest of the car is in good shape what could be the problem?
Oct 17, 2009 | 2004 Dodge Stratus
When i have the heater/defroster on the heater below blows cold air while the defrost blows hot. when i switch to just defrost the bottom heater stays on and blows cold air. when i have front dash and...
It sounds like you have a blend air door stuck. This is in the housing of the heater a/c blower unit under the passenger side of the dash. There is a motor on the top of the housing that could possibly be stuck or on working.
May 10, 2009 | 2003 Dodge Durango
1999 dodge stratus heater blows intermittent hot and cold
HI its almost certainly a thermostat problem, Change the stat and refill slowly with the engine running to eliminate air locks in the system. Hope this helps
Apr 19, 2009 | 2002 Dodge Stratus
Heater doesn't blow hot air
First check the coolant level in the radiator. Check your heater core hoses on the firewall underneath the hood. Let the car come up to temp. and feel the two hoses. If only one of them is getting hot you may have bad heater core or a bad heater control valve.
Jan 04, 2009 | 2003 Dodge Intrepid
Heater is blowing cold air 1999 dodge stratus
A heater blowing cold air can be a few things. have all of these things check for proper operation to find the source of the problem.
1. Coolant level
2. Thermostat
3. Water Pump
4. Heater control valve
5. Make sure that the heater control doors are closing when you switch from hot to cold.
6.Last but not least if the climatic controls are electric it maybe at fault.
Good Luck
Dec 09, 2008 | 1999 Dodge Stratus
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
