Question about Bose Lifestyle 28 System
Lifestyle 30. sound stops, i unplug and plug back in and works for short time and quits. unpllug and plug back and works a short time and quits.
    President:
  • Bose Master
  • 1,114 Answers
What you describe, sounds like a speaker short. Are you using the Bose wiring with their ends and no cuts in the wire? (splices) It's not too uncommon to extend or shorten a wire. The fastest way to find a short is to disconnect your speakers at the speaker. Be careful to keep the wires separate if they are not on plugs and turn on. If it cuts off (power) or says (protection) on the display that lets you know your speakers are ok and you have a short in the system or a wire. Next, disconnect wires at the sub one by one and test until it causes the system to cut off or short. Leave that speaker disconnected from the sub and test with all others connected. Now you've located the channel that has the problem. First just connect the wire again to the sub. if it cuts out, run a new wire from the sub to the spkr, for testing purposes make it a short wire if possible and test. If you need to use a Bose plug at the sub to test spkrs go buy one at Bose, don't cut your factory wire just yet. If a new plug works then cut and replace. Make sure you use electrical tape not scotch tape or duct tape. If it works fine, test the new plug on the old wire and see if it works. If it does your done, if it doesn't, run a new wire to the speaker with the new plug on it. If after all this and it still doesn't work. Sounds confusing I know, It's just process of elimination, that's how we do it in the field. If all your speakers are disconnected and it still cuts out, it could be the sub or the receiver. Take it to a Bose store and they can check each piece for functionality. If it needs repaired let Bose do it. Hope this helps.
Posted on May 23, 2009
My WAN port does not appear to work. (Data does not pass through it.)
Unplug the power to your modem and router boot the router up after 30 seconds wait for all the lights to turn on then boot up the router
Mar 02, 2014 | Linksys Wireless-G WRT54GL Router
Mouse quits working, have to keep unplugging and plugging in
It sounds like a short in the mouse's wiring. Best to get a wireless mouse if you use it alot
Jul 15, 2010 | Dell U0636 Mouse
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
No power
Sounds like the internal 1.6 amp fuse has blown. Its quit easy to change, check the replies I've sent to get access to the unit and the internal fuse.
Oct 04, 2009 | Bose Lifestyle 12 System
Bose Lifestyle 12 system control unplugged and plugged back in
it could be a bad wire or circuit boaed for the speakers sound but seeing i'm not looking at the item in question it's really hard to say what it could possibly be
Jun 22, 2009 | Bose Lifestyle 12 System
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Can not get any sound to work on my bose 28 life style system first time using it. and got a new tv
If you have no sound from any source (CDs and radio included) then check the Audio Input cable at the back of the media center. Make sure it's plugged into the top portion of the 'speakers' section into where it says "main" and not "BoseLink"
If this is fully connected, but still no audio- check to make sure your Acoustimass module (subwoofer on the floor) is plugged into a working power outlet. If that fails, try unplugging both power cords for the system for about 30 seconds.
May 31, 2009 | Bose Lifestyle 28 System
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
No sound from Direct TV box
Unplug the Bose Media Center from the wall. Leave unplugged for approximately 30 minutes. Then plug the unit back in. Allow a few minutes for the Media center to initialize. Your sound should return as normal.
Jan 08, 2008 | Bose Lifestyle 38 System
Bose Lifestyle 28 System Logo
511 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
