Question about HP PSC 1315 All-In-One InkJet Printer
Printer not on
My hp 1315 printer not turn on while all plugs are properly connected.
Re: printer not on
There is a diode in the board code S448, position CR7 near the I.C. U8. try replace it.
Posted on Oct 19, 2007
0 characters
3 Points
I have a psc 1315 all in one printer. When I turn it on it shows it has paper and no errors. When I go to print it won't feed in the paper and just goes into error mode and says check paper. I have the...
try resetting the printer:
  1. Turn on the PSC 1315 by pressing the "On/Resume" button until it lights up. Ensure the printer's USB cable is securely plugged into the back of the machine and the attached computer.
  2. Remove the power cord from the back of the printer. Do not unplug the other end of the power cord from the power outlet.
  3. Press the power cord back onto the metal plugs located on the back of the printer. Make sure you insert the power cord completely into the plug area to ensure a proper connection.
  4. Press the "On/Resume" button on the printer's control panel until it lights up. Allow the printer to complete its warmup process.
  5. Attempt to print with the device if no error messages are displayed.
Mar 14, 2011 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One. Just changed ink cartridge, but prints dim and blurry.
Try taking the cartridges out clean them Unplug the power cord from the back of the printer while the printer is off and let it be unplugged for 60 secs Plug the power cord back in and wait for the 30 secs and then insert the ink cartridges it would try to print the alignment sheet... plz complete the alignment and it should work properly after that
Oct 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP1315 doc's in queue will not print or delete????????
Dear Ralph
plz check ur printer cable from both end if they are connected properly or not , if the cable connected then uninstall the printer driver and restart the system . After restarting the system then reinstall the printer driver with proper port configuration setting (For USB Cable - Port DOT4 or USB & For Com Cable Port LPT or Com) then after installing restart the system again and when the system start then check by giving print .
Jun 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
My laptop cannot recognize my new printer HP 1315 series
this is the link for your software/driver for your printer
be sure to select your correct Operating system
do not connect the printer until the software installation prompts you to plug it in
Jan 25, 2009 | HP PSC 1315 All-In-One InkJet Printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
PSC wireless scanning
Print servers do not usually allow scanning as XP and Vista.
May 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
41 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
