Question about Welding Tools
Bad diode? pull the trigger it goes hmmmmmm!! then blows the breaker. 75 amp tote mig
  • badenhop
    badenhop May 11, 2010
    Make, model, description of how we're trying to weld? Are you able to strike an arc? Did you just buy it?
  • Eric ersland Apr 03, 2012
    If it's a carry unit they sometimes get shorted from welding current to welder chassis or drive motor,and other circuits thru a forign object bouncing around in drive roll/spool compartment wire can also loop off spool in this scenario locking it up and shorting, once trigger is pulled the entire spool of wire is hot.if trigger wires out to trigger shorts to welding current any where in cable hose or gun this can blow breakers too?
    Problem Solver:
  • 8 Answers
Could be. Could also be a shorted winding in the transformer. I have seen the aluminum windings burn and melt on some welders.
Over the years of messing with welders I have hardly seen many bad diodes....it is usually something else.
To check the diodes, you will need to disconnect them inside and use an ohm meter. Set your ohm meter on a low resistance setting and check them in both directions. If you check a diode and it is like you touched the meter leads together (dead short) them yep it needs replacement. When you test them you should read more resistance one direction than the other, if it reads like it is an open circuit like you didn't touch the leads, then test on a higher resistance setting, if you never do show a reading (infinite resistance) then it needs replacement.
Posted on May 24, 2009
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Breaker blow
You may have a short in the trigger leads that is pulling the weld current back through the leads and through the control cable. The short could be causing the breaker to blow. Can you open up the gun handle (disconnect it from the power source first) and check your trigger leads for cuts or nicks. Also check the outer jacket of the cable for cuts which may be deep enough to allow the current carrying copper to touch the embeded switch leads.
Apr 21, 2010 | Hobart Handler 125 Ez
My wire feed wheel on my lincon sp130 mig welder has ceased to turn. How do I trouble shoot if it is a burned out motor or something else?
Check the voltage at the wire feed motor while the trigger is pulled. If there's no voltage, it's pretty safe that it's not the drive motor.
Also, with the unit unplugged, check the big power (stud) diodes for shorts.
I had a wire feed motor stop because 2 of the big diodes were shorted.
Apr 20, 2010 | Welding Tools
Will 12-3 braided wire be ok to run 187 hobart mig at 75 feet long 30 amp breaker
I would run no smaller than 10-3, preferably 6-3. I've seen more than one welder burn out due to insufficient extension cords. 10-3 is pushing it for 75', and if you ever plan to extend the leads, you will be money ahead getting the 6-3.
Dec 15, 2009 | Hobart Welding Tools
MY CEBORA S21 MIG 190L KEEPS BLOWING FUSE,I HAVE REPLACED TORCH AND LEAD ETC CAN YOU HELP
Does it blow when the trigger is pressed or as soon as the mains power is applied??? If it blows when first turned on it could be the cooling fan or the main transformer or auxillary transformer if it has one. If it blows when triggered it could be the pcb or the wire feed motor ,diode bank or main transformer .
Sep 28, 2009 | Welding Tools
I have a sp 100 lincon pull the trigger it clicks, no wire fd
not diode problem,check enternal wiring and relay for feed motor.
Jun 25, 2009 | Lincoln Welding Tools
I have a clarke 130en mig with gas and it will not weld
The most common problem is that people still try and run the welder with extension cords. 10 ft,25ft,50ft,100ft, these cords all drain and can't supply the energy needed as if you were to plug it straight into a wall outlet. well I don't have a plug outlet where my work is, I need a extention cord. The only solution for not having a handy outlet is a Generator. that will supply the necessary voltage needed to do the job. EXTENSION CORDS ARE A NO NO. also, always double check your ground.
Hope this was helpful, please post a rating good or bad, thank you.
May 02, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Welding Tools Logo
302 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
