Question about Printers & Copiers
Printer prints faint quality
My printer starts prints out document that is very faint and light... setting is default... cartidge is new... cartidge tried on another printer.. quality is ok.. but my printer just prints out very light and faint quality...
anyone know what is wrong?
5 Suggested Answers
  • 293 Answers
SOURCE: light printing
have you adjusted your print quality under Printer settings?
Posted on Sep 13, 2007
  • 6 Answers
SOURCE: Print Quality Settings
Go into your control panel
Select Set Printer Properties
Then printing preferences
Select Fast Print
Then ok all windows
This will now print is fast draft on each document.
Posted on Feb 23, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Laserjet 4250dtn Duplex problem
How is the printer connected.
Please upgrade the firmware of the printer.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is, type FTP://
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Posted on Oct 30, 2008
  • 2120 Answers
SOURCE: How change default print quality setting?
In printer properties.
Posted on Jan 31, 2009
  • 103 Answers
SOURCE: Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
Posted on May 13, 2009
0 characters
1 Points
Print is faint
Clean the print head ... open the printer software in the printer folder and look around for a maintenance tab ... follow the instructions.
May 31, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
The print is faint. The lettering on the excel spreadsheet is Arial Regular 10, colour - automatic and normal font. However, the printed copy appears grey rather than black. Toner cartridge recently...
normally you go to printer settings and look for where it says page quality. make sure the page quality is set to normal or fine. this will make it black. if it is on a setting lower than this it will cause the printed document to appear grey.
Aug 18, 2009 | Samsung ML 1610 Laser Printer
Dell 720 prints faint
Have you gone into printer properties when printing the item then click advanced check what the settings are on. Your default settings may be to print draft quality which produces faint picture because it uses dramatically less ink. If you need further assistance let me know. Also a brand new printer of higher quality can be purchased for around 30$. So repair is definitely not a viable option if it is not a setting problem.
Thank you,
Mar 01, 2009 | Dell Inkjet 720 Printer
HP 400 Printing a blank page
You could try the following Steps from HP's Homepage :
Nov 24, 2008 | HP DeskJet 400 InkJet Printer
MP530 will coply but won't print
Try to replace the cartidge maybe your cartidge is not fit to work properly and also the ink is not compatible with your printer
then after you replace the cartridge do the nozzle cleaning until its ok.
Apr 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Select Fast Print
Then ok all windows
Feb 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at for further assistance, I'll be glad to help you.
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
Light printing
Sep 13, 2007 | HP LaserJet 1100 Printer
Printers & Copiers Logo
502 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
