Question about Canon PowerShot S2 IS Digital Camera
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on May 30, 2009
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
Posted on May 29, 2009
SOURCE: Shutter won't open on Canon Powershot s31s
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Best regards,
Posted on Jul 22, 2009
SOURCE: Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Posted on Jun 06, 2010
Testimonial: "Hey thanks heaps! My favourite little camera is now working well again."
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
Aug 04, 2009 | Canon PowerShot A470 Digital Camera
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
Sep 21, 2008 | Canon PowerShot A520 Digital Camera
Aug 11, 2008 | Canon PowerShot S2 IS Digital Camera
874 people viewed this question
