Question about Epson Stylus Photo 820 InkJet Printer
Trying to get the cover off to clean excessive ink
I cannot find a way to remove the top section of my epson 820 . I have pushed in the 3 white release tabs on the back but something else is holding it from coming off.
please help thanks Jerry
jerry@angels24x7.com
  • 353 Answers
There's more to opening a 820 case then the 3 hooks at the back! Epson doesn't want you to open it - you're stealing the excessive cost of doing the job at an Epson repair centre, for goodness sake!
The first job is to download the service manual from:
http://www.mediafire.com/?m6ouftizois
Now, you might find this mysteriously worded document a bit puzzling - if so report back and we'll try to explain how to proceed a little more clearly.
Posted on Feb 01, 2009
CLEANING PRINT HEAD
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
10. Plugged power back on.
Jun 18, 2012 | Office Equipment & Supplies
My Epson PictureMate shows an error of 0002. I tried shuting down and starting up several times, NG
I have just spent tearing mine apart multiple times....I also have the service manual, There are all sorts of sneaky things you can do to the printer... If you send it in for service you are looking at $70 hour labor. Most repair parts are crazy expensive-- like a printhead is $109! I can tell you how to do alot more than the troubleshooting stuff---like checking ribbon connectors and taking the cover off you you can actually get to parts, let me know!
Nov 07, 2009 | Epson PictureMate InkJet Photo Printer
Top and Middle button keeps flashing back and forth. Problem # 5110
5100 error will occur if the film strips has a dirt or most common if there s a drop of water or blots of ink..film **** strips are located at the carriage unit.when you open the cover
you can see it place horizontally at tha back of the carriage unit.you can try this
1. Open the cover and wait for ink carriage to center
3. Push carriage to far left (should slide easily)
4. Use paper towel and wipe purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Use diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel
7. Pull and push clear plastic wiper (north of purge unit) and wiped it down
8. Slide carriage back to original position
9. Remove Print head cartridge and wipe out excess ink stuck on bottom.
10. Plugged power back on.and test
Sep 26, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
Error Code 6A00 on Canon MP830
try this 1. Opening the cover and wait for ink carriage to center 2. Pull out power cord 3. Pushed carriage to far left (should slide easily) 4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear. 5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel 6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white. 7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down 8. Slided carriage back to original position 9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Jun 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
All 4 lights blinking
I cannot get ink printer out as it stuck in Epson Stylus color 760. I have been clean and extract waste leak ink away. The light is still blink. Sigh
Apr 09, 2009 | Epson Stylus Color 760 InkJet Printer
Epson 6000 prints light colored line every 3/4 inch.
Clean the heads with some InkJet Head Cleaner. Get a syringe like the ones you get in the refill kits, and remove the cartridges. Using the syringe, gently squirt cleaning fluid into the cartridge nozzles in the printer. Note: Not into the cartridges themselves. Leave to soak for a while, and then using a cotton bud, remove any excess fluid. Run a few cleaning cycles and you should find the heads come back to life.
Mar 05, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson 820 styles needs ink and jets cleaned
Hi Mitch - there's more to it then the three hooks you are pushing.
Download the service manual from :
to see how.
Oct 07, 2008 | Epson Stylus Photo 820 InkJet Printer
CANON IP 6700D ERROR6A00
  1. Problem similar on canon ip4300 was solved by removing semi dry ink from black sliding rail. White plastic slide was stuck to the right side (spring was still stretched when printing head I moved to the left). Slide the white plastic slide to the left and clean the rail. This slide must be free to move left and right.
May 27, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
There's more to opening a 820 case then the 3 hooks at the back! Epsondoesn't want you to open it - you're stealing the excessive cost ofdoing the job at an Epson repair centre, for goodness sake!
Now,you might find this mysteriously worded document a bit puzzling - if soreport back and we'll try to explain how to proceed a little moreclearly.
Oct 12, 2007 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus Photo 820 InkJet Printer Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
