Question about Quasar SP-3231 TV
I have a friend with a quasar SP-3231 television manufactured in 1998. When they try to turn on the tv, you can hear the relays engage, but the picture never comes up. Preliminary testing indicates there in no voltage to the flyback or the color guns, but I have no schematic to try to trace the signals in order to determine where the problem is actually located.
  • Michael Parker May 11, 2009
    I forgot to add that there was no sound either. I also tested a transistor that looked like it had been replaced. Seeing as I have no schematic, it makes everything very difficult to trace. There is no glow at the end of the tube, so you may very well be right. The transistor you mentioned may very well be the one I tested. It was an NPN with a part number: D25339, and when I tested it in circuit, there appeared to be a short between all three terminals using resistance measurements with the tv unplugged, and when I tried to take voltage measurements, all three terminals were very near ground. It is good to know I was on the right track. I will have to pull and test the transistor now. If it is the problem it will be about a $25 repair and should be an easy fix. Thank you.
  • 431 Answers
The set you are talking about I am unfamiliar with .. however as an engineer for 23 years I am sure it is not unlike any other CRT TV as you say you have no voltage on the rgb is the tube heater on ( you should see a glow at the end of the tube ) if not check you heater rail voltage , check your oscilator Ht output transistor should be 300 to 360 volts on the emitter if this goes down then the lineoutput satge will not opperate hence no picture and in many cases the audio is fed from the secondry of the Line output transformer hence no sound either .. DO NOT ATTEMPT TO DO THIS UNLESS YOU HAVE HAD TECHNICAL TRAINING VOLTAGES HERE ARE IN EXCESS OF 19 KV to 25,000 Volts DEPENDING ON TUBE SIZE AND SHOULD NEVER BE ATTEMPTED BY UNTRAINED PERSONEL... Vortash
Posted on May 10, 2009
  • clive pearson
    clive pearson May 12, 2009
    your welcome .. by the way should the Oscilator transistor blow again ( almost immedeately , then I would suspect the line transformer has a short on it and needs repalcing .. Vortash
How can I replace the outlet for the cables on the back of my quasar SP 3234E TV?
A "freezing" picture sounds like something other than your television. Do you have a cable box or satellite box attached? They fail sometimes and need to be replaced. (You have an analog TV and "freezing" is a digital problem.)
Jul 22, 2014 | Quasar Televison & Video
Tip
Quasar SP3235 Manual Download
Download Quasar SP-3235 Color Television Manual
Have you misplaced your Quasar SP-3235 Color Television Owners Manual?
Would you like a digital, searchable, pdf version of the Quasar SP-3235 Color Television Users Guide?
Follow this link
to download a pdf version of the Quasar SP-3235 Color Television manual.
I hope that helps.
on May 04, 2010 | Televison & Video
Tip
Follow this link
I hope that helps.
on May 04, 2010 | Quasar SP-3235 32" TV
I need the universal remote codes
TV codes aren't set by the TV. They're set up by the remote control manufacturer, so the codes for your brand may vary with the remote. What you'll need to do is look at the instruction sheet for your control, or visit the manufacturer's website, to find the Quasar codes for your model of remote. You can also find out how to use the code search feature built into most remotes if you can't find a working code.
On the off chance your remote is a One-for-All 4, a very popular model, you can try codes 0051 and 0250. Good luck, and thanks for using Fixya!
Jan 01, 2011 | Quasar SP-2723 27" TV
Can you tell me what year this TV was made Ouasar SP-2723B 27"?
The date of manufacture is usually on the back near the serial number on most tv's.
I hope this is helpful.
Bobya
Oct 18, 2010 | Quasar SP-2723 27" TV
Does have my quasar model sp 323 tv have an ATSC tuner? was made in 2001?
No,all tvs have CRTS(Tv Tube).Are analog tvs,don't have ATSC tuner inside.
Oct 18, 2010 | Quasar SP-3234 TV
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Is our Quasar TV (SP2723) a digital or analog television?
That's an analog TV and would need a converter box for the new digital broadcasting.
Nov 28, 2008 | Quasar SP-2723 27" TV
Quasar SP-3233 TV
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
Aug 10, 2007 | Quasar SP-3233 TV
Televison & Video Logo
116 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
