Question about Nokia E71 Smartphone
Nokia e 71 no power even it comes keypads ineffective
Sometime when i press the power button it comes alive after two seconds it goes off even when it stays the key pads are ineffective
Someone told me their is a light sensor in the phone and the light that lights up the keys wont come on in daylight when you can read the keyboard clearly..
Posted on Feb 03, 2011
My nokia e 71 mobile if i press the contacts key it will not display the contact? showing sign up create account and sign in using existing acc what is the problem how can i fix
I Have reason to believe your buttons on your phone are not put on handset correctly. Visit a Nokia outlet nearer to you to align the keypad as it seems you opening email account setting which is button below the contact button
Nov 20, 2014 | Nokia Cell Phones
My nokia e71 loops and does not come on
Hello"::"
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 22, 2013 | Nokia E71 Smartphone
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
How i lock my nokia e 63
You can lock your nokia e63 by pressing the left key and quickly pressing the action button(small button at the bottom left corner of the keypad) .
You can also press the power button down shortly and then select the second option which say lock keys.
hope this helped you? please contact me for more information.
Dec 31, 2010 | Nokia E63 Cell Phone
IPhone 3G sometimes hangs up and shuts down after call ends. It takes a few seconds before I can even power it up again.
1. Turn on your iPhone (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPhone will power off after 10 seconds, but keep holding those buttons down)
3. After the iPhone powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPhone is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPod is in DFU mode.
5. Now iTunes will see it as a DFU’ed iPhone and should ask you to automatically restore its firmware.
6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
7.then jailbreak your phone and unlock.thats all
Jul 22, 2009 | Apple iPhone Smartphone
Nokia 6510 keypad problem
i think u have to clean ur phon.. open it & just wipe it.. im sure it will work
Jun 01, 2009 | Nokia 6510 Cellular Phone
NO DETECTION OF KEYPAD ON THE NOKIA CELL PHONE
take of the battery while the phone is still is alive
if it doesnt work try formatting(aftersaving ur files in the computer)
press the (greenbutton + * + 3 ) and while pressing these switches , switchon the mobile
i know it sounds funnyand its a long process(40 sec) but shld help if its a software problem
PS;the above key combinations should be done only when the phone is in the switched off stage
the key combinations should be kept on hold while pressing the power button for abt 10 sec
if none of these work better take it the dealer
May 18, 2009 | Nokia 5320 XpressMusic Cellular Phone
Nokian73 not switching on!!!
i need the nokia n73 software download .my email address: www.mallikarjun2510@yahoo.com
Apr 24, 2009 | Nokia N73 Cellular Phone
Problem with my nokia e-71
Hi simply turn on the phone and press from you keypad
*pw+CODE+1# it will say restriction off...if not do the same method but apply 7 instead of 1.........that will unlock
thanks
Shaan
Jan 27, 2009 | Nokia E71 Smartphone
Nokia E71 Smartphone Logo
218 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
