Question about Vizio 6100BC0-N03-R Remote Control 0980-0305-0020
6100BC0-N03-R directv looking for DirecTV programming codes for vizio remote. Should be a 5 digit number.
    Top Expert:
  • Vizio Master
  • 76,099 Answers
02856,02817,02881,02892. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Posted on Dec 04, 2013
2 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: remote code for vuz8 remote magnavox blu ray mbp5220f
replace the batteries by new ones
2) clean the contacts batteries with c. cleaner
3) retight the springs contacts batteries, with pliers for a GOOD contacs very importan.
4) open the remote c for clean the KEYpads from corrosion, dirty, dust, oxide, and try again with c. cleaner.
5) reset the code download from www. remotecodelist.com
6) if doesnot work go to the repair shop TV for fix it.
God bless you
Posted on Sep 10, 2012
Can you give me the codes for the lg tv so I can program my remote to my new tv or a diffent way with out the codes please
hi Tammy.
this is all i could find.
4 & 5 Digit Universal Remote Control Codes For LG TVs
  • DirecTV (directv - direct tv) Remote Codes For LG TV: LG 5 Digit TV codes: 11423, 10178, 11178. ..
    PRESS IN THIS ORDER:
    "Menu" - "Settings" - "Remote" - "Program Remote" - "TV"
    Slide mode switch at top to "TV" - enter LG - press and hold "select" & "mute" buttons
    Wait for light to blink 4 times
    Enter 10178.
    Follow instructions.
    If volume does not work then repeat and enter code 11178.
    RCA universal remote codes for LG tv:
    LG TV codes: 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097,
    1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1149, 1171, 1205.
Dec 15, 2017 | LG Televison & Video
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Televison & Video
Tip
  1. Turn on the TV.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
code.
OK.
Jul 06, 2011 | Televison & Video
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Programming with DirecTV remote
Since the flood of new models is great, your remote will never have the capability to control all brands and models. Vizio (like many others) is a very new name in the marketplace so if they did not choose to mimic the IR system of another, more wide-spread brand, you may never have a code set in proprietary remote such as yours (and mine from Dish Network). Even the 'learning' remote I bought will not accept the control signals from the lousy Ilo we own either. Your provider, DirecTV may have some newly developed partially effective code sets so check the support section of their website.
Apr 22, 2009 | Vizio GV46L 46 in. LCD Television
I have a Directv RC24 remote control. I am trying
1. Locate the DIRECTV Receiver's brand and model number
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
6. Using the number keys enter the 5-digit code. If performed
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
How can i program my rc16 direc tv remote control to my philips tv
1.Press menu on your remote and then go to settings and press select on setup.
2.Go to remote and then go to reset remote.
3.Press and hold MUTE and SELECT until the light above the mode on tv switch on the remote flashes twice.
4.Enter the code using the numbers on your tv.
5.you have cleared AV1,AV2 and tv modes.Move the switch back to DIRECTV;press select on done.
Jul 10, 2008 | Directv RC23 Remote Control
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
Vizio 6100BC0-N03-R Remote Control 0980-0305-0020 Logo
130 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
