Black & Decker Firestorm Slide Battery  Logo
Posted on May 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get the drill bit out!
I can not get the drill bit out of my drill
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on May 23, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
Helped
119141
Points
551
IT SOMETIMES HAPPENS WHEN THE SAME BIT IS USED WITHOUT REMOVING IT,HOWEVER I WOULD TAKE 2 PAIR OF CHANNELLOCKS TO OPEN THE CHUCKIF THE BIT IS STUCK TO DEEP IN THE CHUCK YOU MIGHT TRY A LITTLE AND I MEAN ALITTLE PENNETRATING OIL.HOPE THIS HELP'S
1helpful
Why cobalt drill bits are preferred over the titanium drill bits?
The reason for choosing cobalt drill bit over titanium one can be as follows:
It can drill even the hardened steel. It's really amazing to see how they just cut through the steel materials. These tools can also be used to drill through stainless metals and that too very smoothly! These were the reason why cobalt drill bits are preferred over the titanium drill bits. You can check Cobalt vs Titanium Drill Bit for making the best choice.
Apr 16, 2018 • Drills
Which drill bit should I prefer to drill a log of wood?
You can use a spade bit, hole saw or forstner bit in order to drill into a piece of log. I was also looking for the best drill bit to be drilled on a piece of wood, then one of my friends recommended me to check Best Forstner Bits to get an idea about making the choice of an appropriate drill bit. You can also do the same, if you are confused of making the right choice!
I am trying to drill through old encyclopedias, but the drill bits keep snapping in the pages. What type of drill bit can I put on an hand-held drill that will get through the books without breaking?
rx-dk-diy054036_wood-drill-bits_s4x3_lg.jpgI've used 'regular' high speed drill bits for paper, and wood boring bits. I think the wood bits work better, but whatever bit is used the drill flutes have to be cleared out of material. This is done by drilling a little bit at a time and then lifting the drill out of the hole to clear the hole and the drill of shavings. This is essential to do to minimize heat buildup and binding of the drill bit. The drill bit should not break if you take it nice and easy, and drill in small increments .
Drill overheat
Soap might work. Some use candle wax, bees wax, WD 40. I've prayed silicone on the drill bit. Using moderate pressure and low speed definitely helps, and it is essential to clear out the hole of chips frequently. So drilling in increments works. You drill a little, lift the bit up out of the hole to clear the chips. Also the type of bit used is a factor in drilling efficiency: wood boring bits are a good choice. Forstner bits are excellent, and spade bits are just OK. Hope this helps....
Oct 15, 2013 • Drills
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
1helpful
Can i use any drill bit for drilling ...........in any drill machine or different drill machine have thier own drill bit
the teyx bits are SDS Max which are common in the industry. Most hammer drill manufacterors make a SDS+ size drill and a SDS MAX size drill. Hilti calls their bits TEC and TEY.
Putting new bit in my skil9. I'm relatively new with my drill and i'm trying to hang curtains so I need a bigger bit in my drill
Hold the black part on the end of the drill with you hand firmly and then run the drill in reverse...that will loosen the bit...
Place the next bit into the drill and then holding the end run the drill forward till the bit is tight...
heatman101
I can't get the the drill bit out of my cordless drill
Try to keep your drill straight and try a bit harder - looks like you were drilling something very heavy.
1helpful
2answers
Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Drill doctor won't sharpen bit
sounds like the angles have been cut wrong on the bits or you are drilling too fast
Top Black & Decker Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
