Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
BRAVIA KDL-V32A12U PICTURE LOSS
TV comes on for 45 minutes to an hour and then looses picture and sound. The red power/standby light flashes 3 times at 2 second intervals. After switching off and on again it comes on for a few minutes and repeats the symptoms. After several hours of being switched off the above can be repeated.
mistersony
  • 320 Answers
SOURCE: Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Posted on Oct 18, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Standby button (red) flashing on tv. tv turns on briefly(no picture) and then turns off with flashing red light re-appearing.
Try tv unplug,replug about an hour later.The tv now,resetting to factory setting.The tv now,should work.Not than,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 08, 2010 | Sony BRAVIA KDL-40V3000 Television
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture Disappeariing
How many flashes are happening? If its 4 then maybe a bad panel.
Jan 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
