Home
My Products
Sign In
Back to:
All Products
Heaters
Troubleshooting
Tags
NO HEAT
heater
TOO MUCH FUEL
Get a restriction
LPG
Generic problem for all Heaters
Dayton 3E406 60,000 btu shop heater, s\n 28957851
posted by
birdboy
on Oct 12, 2007
Report abuse
can you supply me the parts to convert the above mentioned heater to LPG ?
Solve This!
I have the same problem
Post a new problem
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Solution #1
posted on Mar 01, 2008
Guest
Rank:
Apprentice
Rating:
0%, 0 votes
wont stay lit
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dayton 3E406 60,000 btu shop heater, s\n 28957851:
I don't want to Accept this solution
Done
Solution #2
posted on Oct 15, 2007
Buffalo12980
Rank:
Wiz
Rating:
85%, 869 votes
Grainger says this unit cannot use an alternate fuel. Go to the grainger site and look under notes and restrictions.
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Done
Suggest a new solution for this problem
This Problem Also Relates To:
Coleman 5031-750 Utility Heater
Coleman (5035A751) Heater
Honeywell HZ-325 KAZ Ceramic Compact Heater
Honeywell HZ-710 Oil Filled Radiator Heater
Honeywell HZ335 Ceramic Compact Heater
Honeywell HZ780 Oil Filled Radiator Heater
Honeywell L4064B2236 Fan/Limit Control Heater
Can you Help with these Heaters problems?
Honeywell Electronic Programmable Heat/Cool...
inducer and ibm turns on and stays on no heat or cooling
it is a honeywell furn the fans run nonstop no matter what...
Answer This...
Goodman GMS90703BXA Heater
goodman model aruf486016 no heat fan runs
goodman model ARUF486016 no heat fan runs changed...
Answer This...
Leisure HOMEPRIDE Electric Fireplace Heater...
My Heater stopped working on my HEF33 Electric fireplace
My Heater stopped working on my HEF33 Electric fireplace....
Answer This...
Honeywell Programmable Thermostat Heater
Honeywell Thermostat Problem
I've noticed several times this winter my heater not being...
Answer This...
Lasko 5520 Ceramic Compact Heater
How do I access the filter in a Lasko 5566 ceramic heater
I can't see an easy way to remove and clean the air...
Answer This...
Let FixYa Experts
Solve Your Problem
Ask!
Loading problems.
fairl
Wiz
Let our Experts
solve your problem
for FREE
Chat Live Now!
Repair Service
Find Heater Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Select a category
Additions & Remodeling
Air Conditioning
Appliances
Audio/Visual & Computers
Electrical
Garage & Garage Doors
Heating & Furnace Systems
Home Security Services
Hot Tubs, Spas & Saunas
Landscaping
Plumbing
More Categories...
Zip code
Find!
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
