Question about Philips 55PP9352 55" Projection Television
Blue out of whack around sides
I have a Philips 55PP935217 that just recently had the blue convergence go totally askew.  The center area of the picture is fine, but around the sides and somewhat on the top and bottom, I cannot converge the blue.  Around the bottom, parts of the blue look crooked, like they're leaning towards a common point, but I'm not sure what that point is.  Is there any way to manually move the blue lens without messing anything up?  It seems if I were able to move the lens to the left about an inch (if looking at the front of the screen) then everything would be fine.  Am I just dreaming here, or is that possible?
  • Anonymous Nov 11, 2007
    SAME
  • Christopher Hintz
    Christopher Hintz Feb 29, 2008
    blue askew around sides and some top and bottom not able to move convergences lines left or right only up and down
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Posted on Oct 15, 2008
    Problem Solver:
  • 12 Answers
Found the problem to be convergence chips and resistors. i dont remember the numbers off the top of my head but they can be replace (soldering required) and new heat transferance paste. fixed my problem.
Posted on May 30, 2009
Same
Posted on Dec 14, 2007
Model 55PP935217 multiple convergence mode, the blue colored + is pulsing after IC chips #7044 and #7045 were properly replaced and resistors (12) were good. When single convergence mode is selected, the...
I understand your frustrations, and if you did the work yourself you can feel really bad. In this case if you really want to save this TV, I would suggest you visit Union Electronics. And purchase a reworked replacement board. In many cases this is the best route to go and the price is reasonable. Call them at 1 800 648 6657. I have had very good luck with this company! And these boards are guaranteed, ask for the lenghth allowed. Have your TV model # and tell them you are looking for the convergence board. Thanks for asking!
Aug 08, 2010 | Philips 55PP9352 55" Projection Television
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
I cannot get the blue convergence on my philips 55pp935217 to line up. the red is fine and the center of the blue will adjust but the top right and middle left will not adjust at all. is this a board...
You have a bad convergence IC. I would recommend replacing both. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating!!!
hardrocko
Apr 27, 2010 | Philips Televison & Video
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
55pp935217 Way too much blue
No sounds like the blue CRTs coolant has congealed and thats whats giving you the trouble. the blue tube get congealed and will cause the blue to not even show up properly in the convergence menu
May 18, 2008 | Philips 55PP9352 55" Projection Television
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 55PP9352 55" Projection Television Logo
440 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
