Question about Garden
The blades stop and the 20 amp blowes on My YTH
The blades stop and the 20 amp blowes on My YTH 1524 hydro
  • michael
    michael May 11, 2010
    do they stop when you hit something or by them selves the fuse should blow either way too save from burning up anything else,i didnt look it up but im assuming this is an electric mower?
  • 246 Answers
Hello:
This Sounds like a Bad PTO.
The Following is a Basic File I Made for Checking the PTO (Blade Engagement). The Most Common Cause for this Problem is the PTO Ground. A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO. Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire. Clean the PTO Ground and All the Connections for the PTO Wiring Harness. If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
How do you fix slipping transaxle on yth 21k46 Husqvarna riding mower
Hydro units are not adjustable, check the belt from engine to hydro pulley is tight,check the disc brake is not bindind, this is on the side of the hyro unit and is adjustable,if all is good then the hydro unit itself is suspect.
Jul 25, 2017 | Husqvarna Garden
I have a Kyocera Hydro and my Google play app is stopped. How do I fix it?
oogle play services has stopped - Google Product Forums
productforums.google.com/d/topic/play/ogWU42sBkOw
Google
Sep 10, 2015 - 27 posts - ‎18 authors
Check your apps from Google Play Store > My Apps or Application Manager list. ...My phone details: Kyocera Hydro Vibe model C6725.
Kyocera Phone Apps Crash - FreedomPop Forums
forums.freedompop.com > ... > Kyocera Hydro Icon
Sep 20, 2015 - Hi, @Jorge M. @admin I have 2 Kyocera Hydro Icons, and they both have this issue. ... Ever since I updated the apps/and Google Play services, whenever I open up an .... once I reverted back to the stock version everything stopped crashing. ... And how can I back up my apps/settings if I were to do that? 0. Kyocera Hydro Icon Fix Till Google & Kyocera Give the Proper ...
Nov 16, 2015
Tethering on FP Phones and Google Play Services Crashing ...
Nov 7, 2015
More results from forums.freedompop.com
Google Play Services not Working :( ' Page 2 ' Android Forums
androidforums.com > Android Phones > Kyocera Hydro Vibe
Feb 03, 2016 | Kyocera Cell Phones
First service my YTH 2448
First service is engine oil change and oil filter if fitted, air filter change, in line fuel filter change, check sharpen blades, re tighten all externall nuts and bolts, no need to change the fluid in the hydro unit, just check for any external leaks, allow a couple of hours to do this.
Apr 04, 2013 | Husqvarna Garden
What type of fluid goes in husqvarna yth 150?
Hydro gear box takes a sae 20w 50 motor oil, Tuff Torq takes a sae 10w 30 motor oil
Oct 20, 2012 | Husqvarna Yth 150 Riding Mower Illustrated...
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
On my 3 year old YTH 22V42, 20 A fuse blows out as soon as PTO switch is engaged.
pto stich is just a toggle off on switch, check it for grounding some where
check the wire from it to the pto for grounding out
or its in your pto its self
Jul 24, 2011 | Garden
I have a Husqvarna Yth 180, the lawn mower shut off when I engage the blades to cut grass. I blows the 20 amp fuse near the wire harness
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Jul 13, 2009 | Husqvarna Garden
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
201 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
