Question about Motorola Mobility RAZR V3
White screen Both my screens on my rax-r are gone most of the time. Inside one is white and outside one is dark blue. I looked here on how to help myself, but not much info on this problem. Can you suggest anything before I send it to repair? Thanks. Daniel :)
  • danielmilton Oct 12, 2007
    I meant my razr-v3
  • 425 Answers
Hi
try opening your phone and check if its flex connector is still in contact.  if everything is fine then probably you have a problem in the flex itself...
if eveything is fine then worst you have a defective LCD..
Posted on Oct 16, 2007
The screen has gone dark but can just read it.
it should be on the left side of control panel if you look closer one wheel for lcd light adjustment, look from down side.
Dec 10, 2009 | Toshiba e-Studio 232 Black and White...
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Optoma HD72 displays white circles when the picture is dark
Have your projector professionally cleaned. It is dust in the inside optics. You should not attempt unless you are very skilled. if you are going to do this yourself have a lot of compressed air on hand.
Aug 25, 2008 | Optoma HD72 Multimedia Projector
My Razor Front screen wont work
you will need to replace the LCD on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Outside screen is blue
have the lcd replaced on both phones.
Mar 08, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Black Outside Screen
When you are looking at the RAZR, push the button on the right hand side. This should light up your outside screen to see the time when the screen is dark. Have you tried this?
Dec 23, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
