Every few months, Fridge leaks water under freezer. Tech comes out and says drain line is too small and will happen every few months because it cannot be replaced. Is it normal for a 2 year old fridge to leak this often?
SOURCE: Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
SOURCE: Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
SOURCE: WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
SOURCE: Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
SOURCE: my no frost is leaking water from under the
You have a clogged drain tube in the freezer . here is how to repairit. take off the ice maker if it has one. then remove the 1/4 ince screws in the back. the whole back panel will come off.depending on the ice build up you might have to defrost the unit. if you would like to easily fix it just unplugg the unit and let it defrost. defrosting will unfreeze the line. this will sovle you problem for a while but it will happen again.
