Question about LG DLG2525S Electric Dryer
LG DLG2525S gas dryer wont heat up. Cooling light stays on.
SOURCE: LG DLG5988W Gas Dryer (NO HEAT)
got mine repaired.. They replaced the gas valve. Initial review is that its not drying as well as when it was new. I will use some more this weekend to confirm.
Interesting point on the washer....i have the same one i think (2277? - can't remember either). I've probably had the same issue with the bleach and never made the correction since I don't inspect the clothes before moving them over to the dryer. I will keep my eye out for that issue.
Never had the clunking noise though from the dryer.
Actually, I've been pretty happy with the two units until the dryer stopped heating...
Posted on Dec 19, 2007
  • 8404 Answers
SOURCE: DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Posted on Sep 25, 2009
SOURCE: lg tromm dryer electric cooling light staying on
I started researching on here because I was having the same problems with my LG dryer. (It also happens to be the same model.) I discovered the vent hose was kinked.
With the lights, the cycle it's on that blinks. When your dryer gets to the last 5 minutes, the "Cooling" light will blink and the "Drying" light will go off. If you have the "Wrinkle" setting on after the 5 minute cooling cycle, the wrinkle cycle will start and circular lights will show where the minutes normally are displayed and the Wrinkle light will blink.
Posted on Dec 11, 2009
  • 56 Answers
SOURCE: LG c70040e dryer not heating.
some there a reset button on the rear red give it press in wards and then try agin and see if it works
Posted on Feb 12, 2010
ftw1952
  • 10319 Answers
SOURCE: my lg tromm dlg2525s dryer is skipping time during
You have a faulty timer that needs to be replaced. One or more of the cogged teeth are stripped inside the timer
Posted on Apr 14, 2010
My Lg Dle5977s, will not heat up, had new heating element installed and it work at the repair shop, the cooling light is staying on
Check power to both legs of you 220 v outlet.
Cooling light always stays on-not an issue.
Sep 01, 2017 | LG Dryers
The dryer won't dry. I was using dryer sheets and the service tech said don't do that. So I cleaned off the sensor with mild soap. I also replaced the exhaust with flexible metal vs the foil coil type I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 12, 2010 | LG DLG2525S Electric Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
a
Sep 25, 2009 | LG DLE7177 Dryer
Dlg2524 gas dryer runs but won't heat and the cooling light stays on it also seems like the heating element is not igniting
Check the vent going outside , many time this is the number 1 problem the vent it plug up or the pipe is kink
Apr 15, 2009 | LG Dryers
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLG2525S Electric Dryer Logo
254 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
