Question about GE (PSS26MSRSS) Side by Side Refrigerator
Internal temp of fridge and freezer are different from bottom top
I picked up a used GE side by side fridge (Aproximatley 1993), after a major cleaning I plugged it in and let it run for a day. Now in the freezer the temp at the bottom is 5 degrees and froze a bottle of water, the temp at the top of the freezer is 60 and the bottle of water at the top is reading 55 degrees. The fridge is 32 at the bottom and 70 at the top, I measured this by both aiming a lazer themometer at the sides as well as using bottles of water placed at different levels. The setting for the freezer is at 9 and the fridge I just upped from 5 to 7.
  • rjbeg123 May 11, 2010
    There should be a freezer circulation fan running. You should hear it when you first open the door. If not you'll need to track down and see if perhaps it got wet and shorted out, or it got to hot and warped. and is catching on something and not working. In any case that's what circulates air in the freezer and pushes air into the fridge as well. Since hot air rises you need a fan to circulate the air.
    President:
  • 1,136 Answers
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
Posted on May 10, 2009
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side x side refridgerator temperature is
unlikely both temp.sensors will be faulty at the same time. Notice how different the internal temps.are compared to the acurate one you are measuring it against. Almost certain board is defective because incorrect info in the processor will tell the compressor/s to switch off before time.(hence not correct temp. all the time.) Suggest replacement.I normally replace probes as well to eliminate problems later..
Sep 17, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Not cold enough
I opened the bottom panel at the back of the fridge and cleaned the coil because it was completely covered with dust and lints and less than an hour later the fridge side temp started going down and the freezer took five hours for the temp to start going down when we didn't open it for that much time. It's back to factory setting now and thanks for the blogs that I read that I was able to try different possibilities. Your site is very helpful.
Mar 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
My GSS22SGRE sise by side freezer & refrigerator temp is too warm
The defrost function on your refrigerator has malfunctioned. It is a possibility that That it could be the heating element, the temp sensor, or the main board. I am posting a couple of videos to help you out.
This next video will show you a defrost issue in a top bottom fridge and explain how a refrigerator functions. Now all fridges function on the same principle on cooling and defrosting however the only difference you will usually find is location of the coil whether it is a side by side or freezer on the bottom.
Jun 12, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE not Cooling
FREEZER ON THE TOP OR BOTTOM ?
Dec 19, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
190 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
