Question about Honeywell Programmable Thermostat Heater
Numbers are not displayed on the thermostat and it is putting out cold air
    Genius:
  • 1,847 Answers
This link should be of help..
http://www.fixya.com/support/t488500-honeywell_t8001c
let me know if you need further assistance
Thanks
Kevin
Posted on May 10, 2009
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
Mitsubishi l200 2.5 DiD 2007 74000 miles, bubbling in header tank, over heating and pushing water back to the header tank, heater is still blowing hot air!! So dont think its the thermostat, am I more...
There are other things to test before we have the engine spread all over the yard. Cooling fan operation. Yes the thermostat hot air in heater just means hot water. start with a cold engine then start and run at a high idle if heats quickly upper radiator hose hot lower cold good but reverse no flow. remove and test thermostat (not replace) put on stove boil water and watch it open once center piece is moving check with thermometer it should agree with stamp number on thermostat. if good check for slipping fan belt. check for air restrictions on radiator and water flow.
May 04, 2014 | Cars & Trucks
My car over heating and blows cold air had new thermostat housing done but still dont work
Trapped air you have to bleed the air ,open cap when is cold and start car until water goes up to the top put back cap.try two times.
Apr 03, 2013 | Cars & Trucks
Kenmore refrigerator is freezing the food, what is the problem? Is a Defrost Thermostat the right part?
No it will be the main cold control thermostat...OR if ya have a sisde by side with digital display it may be the damper thats stuck open and letting in too much cold air into the fresh food section..but under no circumstance does the defrost t-stat control the operating temp.of either the fresh food or freezer side
Reply and let me know the exact model number and i will be able to better determine what it may be since it does vary on if its its older or has a digital diplay or side by side ect ect
Sep 17, 2011 | Refrigerators
ON THE THERMOSTAT THE DIAL HAS 1-9 WHICH NUMBER DO I PUT IT ON FOR IT TO THROW COOL AIR
Only guesssing try either way and wait tell the unit puts out cold air but it shuld put it out if you place it on 4-5 .. let me know
Jul 23, 2011 | Goldstar WG5000 Air Conditioner
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
Display in thermostat not showing
Please check the thermostat display connections. If it
doesn't improve, we have no other option but to replace
it. Thermostat Display always have a clear display unless it becomes defective. Hope this will help you.
Jan 06, 2010 | Mitsubishi MSZ09UN Air Conditioner
94 Grand AM NO HEAT, just blows cold air
your description ends. what have you put in...
if you have put stop leak in the car it can clog your heater core.
check your thermostat
check your engine oil if it looks milky you have a head gasket problem aslo check your coolant if there is oil in your coolant you have a head gasket problem
Feb 04, 2009 | 1994 Pontiac Grand Am
Heater blowing cold air
squeeze the hoses to get any air bubbles out and refill coolant as necesary. are you sure you put thermostat in the right way? may be backwards. also may be your sensor.
Jan 04, 2009 | 1991 Dodge Ram
Heating & Cooling Logo
26 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
