Question about Garden
Cant get the spool off to change the line
I have a Homelite gas powered straight shaft grass trimmer and want to change the line but cant get the spool off, can you tell me how to get it off thanks
  • greg562 May 10, 2009
    I dont see any tabs on the spool any other possible suggestions how to remove this spool from my gas powered Homelite straight shat grass trimmer
    It does have a plastic centre nut, it seems very tight I cant budge it by hand, I will try channel locks thanks
  • 122 Answers
Check for 2 or 1 push tabs on the side of the spool that might onlock it so it can be turned too replace string
Posted on May 10, 2009
  • michael
    michael May 10, 2009
    hmmm, ok does it have the center knob that unscrews then ? or the outer ring must turn, might just be jammed up try a pair of channel locks for a little extra grip just use cation not too break it
  • michael
    your welcome hope it works for you
No power when wheel spins
You may have a broken drive shaft. Some are braided and flexable and used on curved shaft units. The solid shaft is used on most straight shaft units. Remove the string head and pull the shaft out to look at the ends to see if they are broken or stripped. George
Jun 05, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
Need a head foe a Homelite straight shaft grass trimmer
May I get the model # to help you more. or you can get parts on the link below.
http://www.ereplacementparts.com/homelite-trimmer-parts-c-18807_20299.html
Good luck please accept the answer
Oct 18, 2010 | Homelite Garden
Have a Homelite gas trimmer. Cannot remove the
Not sure but have you checked to see if it might be left handed thread
Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
How do you take the spool off the Homelite gas grass trimmer?
Push in on the spool & turn counter clockwise. This works for most trimmers. Careful though, the center spring may pop off with the spool. (I wouldn't do it on a hill)
Aug 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite grass trimmer won't automatic feed line when tapped on surface
the problem with it is its a piece of **** excuse for a line feeder if its a mighty lite. mine is new and in perfect condition and getting it to feed string is close to impossible.
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Cant get the spool off homelite trimmer
Unscrew the bump-knob and the rest pulls off. If it won't unscrew you could always cut it off and buy a new one from ALM Manufacturing 01423 797208
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Cant get spool off Turning it anti clockwise. It makes a click noise, but wont undo.
Do not know which model you have but if curved shaft probably a Right Hand Thread which you should loosen by turning CCW. If a straight shaft trimmer probably a Left Hand thread. Many times the LH button will be Red in color. Could be the head of the screw is slipping in the button. If so remove the metal cover plate on the button to get to the bolt head. You will need to change the button out if this is the problem. The RH thread button is PN 308042002 and the LH thread button is PN 308042003.
May 04, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
