Question about Whirlpool GHW9400 Duet Washer
Error code f h
Whirlpool washing machine awo3351 displaying error code f h
  • 2,272 Answers
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter location. error code f h - c3a1d6e.jpg
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 16, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/15 error code on...
    The error F/15 is shown on the display due to Motor Control Unit (MCU) Error detected in the washing machine.
    In this problem check the MCU in the washing machine. The motor is either got stuck up or got overheated and got faulty. This will Help. Good Luck.
    on Mar 11, 2010 | Washing Machines
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/14 error code on...
    The error F/14 is shown on the display due to EEPROM Error detected in the washing machine.
    In this problem check the Central Control Unit (CCU) the ccu is not receiving the proper data from the EEPROM board in the machine. This will Help. Good Luck.
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
    whirlpool have a good fault code list on the net
    go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
    Jun 28, 2015 | Whirlpool Washing Machines
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/13 error code on...
    The error F/13 is shown on the display due to Dispenser Circuit Error detected in the washing machine.
    In this problem check the dispenser motor .Either is blocked or its not running in proper direction.
    This will Help.Good Luck.
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/11 error code on...
    The error F/11 is shown on the display due to Serial Communication Error detected in the washing machine.
    In this problem check the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) .
    Washer display code F05 what is this code?
    the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
    Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/06 error code on...
    The error F/06 is shown on the display due toDrive Motor Tachometer Error in the washing machine. The motorspeed is not getting detected by the control board in themachine.
    Tip
    Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/05 error code on...
    The error F/05 is shown on the display due to Water Temperature Sensor Error in the washing machine.
    Washing Machines Logo
    382 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
